I have some irretating noice when I enganged the pedal forward and reserve on my newly bought B 3150 . Only on H speed, the other two positions quite normal.
Thank you for your answer. I´m taking over the Tractor in the end of March, and I may come back with other ? then, again thank you .I think what your describing is your hydraulic drive amd its normal. Called hydro whine.
You might want to replace the transmission fluid with SUDT2 (synthetic oil). It supposedly has made a difference in the whining on the tractor.I have some irretating noice when I enganged the pedal forward and reserve on my newly bought B 3150 . Only on H speed, the other two positions quite normal.
Thank you for your advice, I´m going thru the hole Tractor when it´s delivered end of March, again thank you !You might want to replace the transmission fluid with SUDT2 (synthetic oil). It supposedly has made a difference in the whining on the tractor.
can we get a little more info? like do you know:I have some irretating noice when I enganged the pedal forward and reserve on my newly bought B 3150 . Only on H speed, the other two positions quite normal.
