Irritate noice when forward/reverse H-speed B3150
K- fan since 1994
B3150 and 27-4 Exc
Feb 22, 2025
Norway
I have some irretating noice when I enganged the pedal forward and reserve on my newly bought B 3150 . Only on H speed, the other two positions quite normal.
1,553
You might want to replace the transmission fluid with SUDT2 (synthetic oil). It supposedly has made a difference in the whining on the tractor.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
709
599
E.
can we get a little more info? like do you know:
- does the noise change between a warmed up engine/oil and cold?
- is it worse in colder temps say at -30 versus say +15
- does it change if the operating rpm set low/med/high
- when engaging the "pedal" in high range are you feathering into it until machine is rolling or are you hitting the pedal hard and fast (like dumping a clutch on a sports car in 3rd gear at low rpm versus dumping in 1st gear at higher rpm )
- is this occurring when pointed uphill and downhill (aka worse when more load on it)
- do you have any equipment hooked to the back, are tires filled, etc...) also trying to asses a load thing in high range.
7,495
Evaluating sounds over text is like... well... Just not good.
Make a video / audio of it doing it and post it on Youtube and give us a link to see / hear it.
You could be having a normal HST whine or you could be having a host of other issues.
5,897
@K- fan since 1994 is from Norway.
Bet it's cold there.
A video/audio would help, like Wolfman said.
If it's only in H range, he may need more engine RPM, or he's trying to do things in H range he should do in L range.
Maybe a change of fluid/filters would help too, as @Russell King pointed out.
