After doing my 50 hour service, I changed the trans fluid in the back and also the front.
I had thought I might have seen a drip on the front once or twice before but wasnt sure.
But when i went to go check the front before draining it - it was low. Now that I changed it and filled it to the proper level I can easily see the leak. Only the right side (passenger) is leaking
Won't leak just sitting there - but if I run the tractor for a few mins (doesn't even have to be moving around it will start to drip out.
I let it run for 5 mins - shut it off and popped the check level cap to see if any pressure was building up but no pop or anything. So must be a bad seal -- or?
I'm a mechanic my entire life but not a tractor mechanic I'm sure I can fix it I just need to know what's involved or what the problem might be
Whats involved/ why is this leaking
any help would be great, to at least point me in the right direction
