Hydro line question
5,678
OK y'all know I had problems with the FEL on the B, and while it is back on I find at least one of the steel hydro lines across the front has a pin hole in it,, causing a real mess. Anyways, I was wondering , because of the price , if a local hydro shop could make on up or if a rubber high pressure line could be used in its place? What say you?
Caden
1979 B7100
Apr 16, 2026
329
188
Not sure how "safe" it is, but I've had success in the past using a brazing rod to repair steel line pinholes.
On the other hand, I would think a hydro shop would have no problem making a steel line.
Tughill Tom
B3200
Dec 23, 2013
1,483
2,173
Turin, NY
Pic's please...... Corrosion, Bent, Kinked ??
#40Fan
656
484
If you could get the replacement steel line for less than a $100, I'd do that. If not, get a replacement rubber line.
4,242
Splice a flared-fitting into it. (not compression)
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,224
1,846
Pittsburgh
I've used this outfit when things went wrong at Perryman: https://www.google.com/searchviewer...2ahUKEwjY4prD8ZmXAxXjGVkFHe06FmIQ_pABegQIDBAH
Take your old line in for fitting and length reference.
5,678
I checked messnicks and yeah about 100 bucks for a 24 inch steel line,,
5,678
DAYUM guys your pretty good and spending my money ;) You guys a re brutal !
