Hydraulics for B2789 Snowblower
Mr M.
Ontario Canada
Hi all,
I was wondering if I could get some help here. I have a B2601 Tractor and a B2789 snowblower for next snow season. I have hydraulics installed in the tractor for the rear mount snowblower but need a kit for the snowblower. Was wondering of anyone has done this or has suggestions on a kit? If there were things to be aware of or potential pitfalls?
Thanks!
7,212
Hi all,
Thanks!
What hydraulics fo you have on the tractor - rear remotes?
What do you want on the snow blower - hydraulic chute rotation?
Mr M.
Ontario Canada
Hey Dan.
Yes to both your questions. Rear remotes and simply want hydraulic rotation.
7,212
I dont know the specifics of that implement but this general idea has been discussed in the past. Basically you mount a small bi-directional hydraulic motor to the chute rotation worm and control it with one of your rear remotes. Heres a picture of the OEM parts. Remove yoke (3) and replace with a short shaft and motor. I would think less than $300 in parts/material and a couple hours work.
Mr M.
Ontario Canada
Thanks Dan!
Any clue where I could source the motor, mount and hoses? I was hoping for a kit. Been looking in Canada finding it hard to source. I could go to my dealership but thought I'd check other ideas and experiences first.
7,212
Thanks Dan!
If the dealer has a kit why reinvent the wheel?
Hydraulic motors and hoses are readily available online. All you need for this is a small low speed motor and a couple off the shelf 1/4" hydraulic hoses. You should be able to bolt the motor directly to the frame with a simple flat bar (torque arm).
Mr M.
Ontario Canada
Good point. Thanks Dan I sincerely appreciate it.
Bearcatrp
Oversized Garden Tractor (aka BX1880) with loader, mower and 3 point
Mar 28, 2023
1,367
992
Minnesota
My SB1051 rear blower came with a long hand crank to adjust my Shute from my seat. Yours didn’t? Or your tired of hand cranking?
Bearcatrp
Mar 28, 2023
1,367
992
Minnesota
Hi Bear!
Just tired of cranking.
Understand. If I remember correctly, someone posted an electrical set up to turn the Shute. I’ll see if I can find it.
Mr M.
Ontario Canada
Much appreciated but I have rear hydraulic switches I want to use. If you see anything on that. Please feel free to share. My Thanks!
