Hydraulic temperature gage
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,236
Ireland
That is a good option if there is a spot for it on the unit.
It will do nothing to inform the operator of the fluid level, but by all means it’ll be a gauge to look at?
I think it would tell you something of the load you are putting onto your tractor. After a while (at different ambient temperatures) you will be able to tell what is correct or if there is a problem.
Will you use an analogue meter or digital display? If you spread the upper temperature range for an analogue meter you get better resolution in the area you are interested in.
I did that with the water temperature (left side), the cold part is really of no interest.
If you modify a pipe it may be an idea to add a hydraulic pressure sensor after the pump as well. This gives you instantaneous load. I have that switchable on the same meter as the engine oil pressure (50 bar range then, my pump has only 35 bar nominal).
7,223
Thanks for all of the replies, good, bad, and sarcastic. I think the best answer I got was that if the fluid got low I would notice a decrease in the performance tractor, makes good sense to me. I think this whole thing got blown out of proportion because of people not fully reading my question in full. All I wanted to do is install a temperature gage "WITHOUT "drilling a hole
anywhere on the tractor.
Just to let you know that I am 86 years old and have been around the block a few times and I don't like to be treated like i'm a 18 year old wet behind the ears kid. The following are some of the responses that I got that I just don't get.
It’s a tractor not a dozer. ??????
Step away and save yourself from bad / dumb / useless Internet video infomercials! This sounds like it comes from a snap on guy that doesn't like my harbor freight tools.
Maybe install an oil level sender in the oil pan. ??????
using temperature to infer level is fraught with peril, sort of like waiting on the oil pressure light to check the oil or the temperature gauge/light to check coolant. Like Hokie said, if you're concerned with level,
View attachment 174159 0
Putting a tee and temp sender in a 2000+ PSI hydrauluc pressure line strikes me as a recipe for an instant blow out. :unsure: If you put it in the loader tank return you only get flow when the bucket is being curled. An oil cooler line seems like a better choice for multiple reasons.
BX23-S,57 A-C D-14,
6,285
There's no reason why you 'can't put temp sensor... in high pressure circuit'. Using fittings rated for the pressure, you can. It's done all the time in industrial process control systems. Used to use Swagelok 10K PSI fittings in 2k5 test 'plants'. Overkill for sure but, better safe than sorry. Pretty sure NASA has a few installed ,here ,there everywhere in the projects they do.
7,223
What do you think the pressure rating is of the average automotive temp sender? People here dont shop at the NASA store.
Dustball
2016 B2650HSDC
Sep 15, 2023
521
384
Hudson, WI
Agreed. If installed on the high pressure side, the pressure rating of the fittings/tee to be installed isn't the issue- it's the pressure rating of the temp sender.
For me, I'd look into seeing if an oil filter sandwich adapter exists and threading the temp sender into that.
7,626
Overall fluid volume has very little effect on operating temperature.
More fluid takes longer to heat up, but short of very extreme examples, it has no overall effect on operating temperature.
Isn't what you state here reasons why a hyd oil temp gauge will not help what you desire to know?
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,178
1,784
Pittsburgh
I, Spraynard, would drill the dipstick (off center) for a .0625" diameter type N mineral insulated metallic sheath thermocouple.
I would do that because I'm hip-deep in .0625" diameter type N mineral insulated metallic sheath thermocouples.
Reactions: 6 users
Trash Panda
L2501
Feb 18, 2022
268
261
Wyoming
It is a reason why a temp gauge won’t help the OP know his fluid level, yes.
You must be mixing posts inadvertently, because I have never proclaimed my desire to associate fluid temp with fluid level.
