Hydraulic fittings
BX2680MR
2018 BX2680
Nov 17, 2024
Reston, MB
Could someone please give me a part # for these hydraulic fittings on this bank. I went to kubota dealer and they can't seem to find them. I need to change the fittings on hydraulic hoses for snowblower so that I can hook them up to that bank or manifold on the tractor. Thanks
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
785
679
E.
is their a number stamped on the fitting?
Princess Auto in Brandon should have what you need.
8,756
They are proprietary you will not get a standard fitting to fit up to them.
A couple choices:
Get another quick connector block and hoses to put on the snow blower. (this is what I would do).
Change the existing connectors to standard couplings.
Dustball
2016 B2650HSDC
Sep 15, 2023
418
273
Hudson, WI
The part number for the male plug is 7J627-85290.
That just happens to look an awful a lot alike the end of a 7J627-66220 (aka Parker FEM-252-4FP).
The female coupler is 7J626-66320 (aka Parker FEM-251-4FP).
I just happen to be selling both the male and female Parker FEM flat face couplers/plugs on eBay as they're popular with the Chinese mini-excavator folks for their attachments if you're unable to locate these locally.
8,756
Looks are good, but...
Have you coupled the female parker to the male Kubota coupling?
8,756
I did a little more digging and Kubota changed that bank of fittings somewhere along the way, so maybe they did end up going to a standard fitting???
BX2680MR
2018 BX2680
Nov 17, 2024
Reston, MB
Thanks for all the replies. The only real definite reply tho was the one saying that my only two options are to get rid of that bank quick attach and just swap all couplers or buy a quick mount coupler for the snowblower. The rest seemed like "try this, try that" https://www.messicks.com/catalogs/kubota/bx23s/pump-motor-system/j21200-hydraulic-pipe-return
Id like to think that I should just order a couple of these and be done with it but it still seems like a guessing game and I'm in the boonies an hour away from any big parts store
5,271
Are you trying to use standard individual female couplers to connect hoses to the male tips on the outlet block?
Dsn
BX2680MR
2018 BX2680
Nov 17, 2024
Reston, MB
And then I climb under there to install this new $500 pto shaft fresh outta the box, and it's too short... just battling here and not getting very far
