How good is alternate energy?
BX23-S,57 A-C D-14,
6,332
re: LED failures
You can easily get 50,000 hrs of life out of most LEDs, IF they're properly powered and protected.
Over 1/2 of the deaths are due to power supply failures(wrong components, poor design, poor construction EMI, etc.).
I've had some T-1 style red LEDs running 24/7 for almost 18 years in TTY controllers and some ULCAA security loops.
Major problem is people want CHEAP products, won't pay a little more for reliablity.
As for energy... Geothermal would be my choice, stable ,reliable, cheap to operate. yes costs a few bucks to drill couple holes in the ground BUT payback is 5-7 years.
Jchonline
600
Red Feather Lakes, CO
re: LED failures
Geothermal requires land...there are millions without it. it is a good option if you can afford it and have land.
Oliver
L2501, JD 3520
Feb 2, 2011
546
140
Preston County, WV
My point is its a huge waste….we should just be putting panels on houses/barns/businesses and leaving the agricultural land alone. We really don’t need it. 12KWH of panels on a standard home that would only use maybe 30KW in a day…tons of excess. Just need the storage.
The problem is we don't have energy storage on a large scale at this point. If every structure generates their own energy (during daylight, wind, etc.) and also has the battery backup to store enough to get through night, weeks of cloud cover, times of little wind, etc. it will work. But 100,000,000 structures needing battery backup systems would be very wasteful, polluting, and expensive.
So if we all only generate some of what we use and forgo having to have our own battery back up systems we simply could ask "big electricity" to be able to supply us reliable power only when we need it, when ours doesn't work. Problem is efficient power generation can't do this, well they can but it'll be *very* expensive. Carbon ore and even gas power plants work well just constantly humming along but asking them to run, shut down, start up, slow down, ramp up, shut down again, is very ineffecient to do and very hard on the expensive equipment. No power plant would be built under that scenario, unless they were paid a lot more for generation when needed plus also paid while they were "on call".
Sometime in the future efficient energy storage (not batteries and probably large scale) will solve the problem.
Jchonline
600
I agree. We can switch to solar now and drastically cut down on daytime usage..but at night we still need fossil fuels to keep things working. It is not a solution, but it is a step towards it.
BX23-S,57 A-C D-14,
6,332
The BIG problem up here isn't generating power ,it's PAYING 'hydro workers' !! EVERY time we've reduced energy consumption, from incandescent to CFL to LEDs, 'they' UP the rates even though we're using less energy. They have HUGE salaries, pensions, perks, benefits that cost billions, so if we use less energy ,the rates HAVE to go up to pay for their 'expenses'. The end user cannot win. If everyone in Ontario went back to ONE LED and a single burner cooktop, the rates would go up even though we'd only need a small nuke.
If 'solar' actually did work, then the lower state would be covered in arrays, but they don't. Simple things like overhead clouds ,dust and bird turds dramatically reduce solar panel output. And again if you reduce your consumption of power, they jack up the rates....
Oliver
L2501, JD 3520
Feb 2, 2011
546
140
Preston County, WV
I agree in some hot areas of the country (southwest) solar panels generate power when it's most needed, in the heat of the day. One problem is (like for batteries) heat is hard on photovoltaic panels shortening their life). Also unless you're in a high elevation you need your AC to run at night as well.
Interestingly Cali code now dictates every new home have solar panels and when they don't need that power it goes back to the grid. Problem is now Cali grid already often has TOO much power during the day, so they offered it to AZ cheap. AZ refused saying they didn't need it. I can't recall what occurred either Cali *gave* the power to AZ or I'm thinking actually *paid* AZ to take it. But in certain conditions, times when solar isn't producing, and in certain areas of Cali they need power. And the cost for a gas plant to inefficiently start up and generate power then shut back down for 10 hours may be as much as just having it operate at a more constant rate for 24 hours.
GreensvilleJay brings up an interesting point.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
3,000
2,372
Western MT
Seems like conservation makes more sense than alternate energy.
When I moved/remodeled my current house, I put in low energy usage QLED tvs changed the fridge, and all LED lights. My power might be cheaper than yours, but my monthly electric bill is almost always less than $75 a month. I also have sunscreens on many of the windows that have prevailing sun this time of year.
I use firewood and propane for heat, and fans and one 12K BTU AC when it is pushing 100.
BruceP
G5200H
Aug 7, 2016
852
374
Richmond, Vermont, USA
I have had other LEDs die in a year.
I have taken apart many 120v "Light Emitting Diode" devices to repair them.
It is farrrrr more likely it is the power-supply to the LEDs which fail. Theoretically, an LED can last a very long time. However, the super-cheep circuits which serve as the power-supply contain substandard components or have poorly soldered connections.
Lets not forget that the LEDs themselves are cheep and reliable.... HOWEVER, they require constant-current power supply which can cost 2x what the LED itself costs. (an LED is a current device... NOT voltage)
This means, when you buy a 120v LED bulb, 2/3 of the cost is the power-supply circuit within the device. Obviously, it is the power-supply where the manufactures cut costs.
Freeheeler
b2650 tlb
Aug 16, 2018
706
527
Knoxville, TN
re: LED failures
My payback was 2 years. Of course that includes the initial tax break covering a large portion, and the fact that mine is lake based so no drilling needed. Even cavemen knew the benefits of geothermal temp regulation ;)
Old_Paint
Dec 5, 2020
2,057
2,364
AL
And as for global warming, the same people lie about everything, ie. race -sex- etc. So who in their right mind would believe them on GW.
Someone got some 'splainin' to do about this year. We haven't had a single day over 85 degrees through 2/3 of July this year, and not a single day over 92. The trend is usually banging up against the end-stops by end of May and 90+ temperatures all summer.
lynnmor
B2601-1
May 3, 2021
1,825
1,624
Red Lion
In PA it has been too hot to leave the house most days this summer. Come and take your heat back, we don't want it.
jimh406
Jan 29, 2021
3,000
2,372
Western MT
In my part of MT, we set a record for most days in a row over 90. It’s also extremely dry here while some parts of the country have record rainfall.
Jchonline
600
Many homes are just junk when it comes to energy efficient design. It will be 50 years before we have enough newly designed houses to really have an impact on AC/Heat use at night. Here in CO the new building codes require an extremely tight home build (less than 8 exchanges per hour I believe) and the insulation requirements keep ticking up every year. It is so much better to build an efficient home up front than it is to use AC/Heat to fix a leaky home. However it is more expensive....so the builder wants to pass the buck.
random
Nov 2, 2020
716
401
NC
Not so sure it's the builder. Yes it's more expensive, and the builder isn't going to build for a loss, so its reflected in the price. TOO expensive and it doesn't sell.
Would you pay $20,000 more for a house that was going to save you $100/month on heating & cooling? That's almost 17 years for the payoff.
lynnmor
B2601-1
May 3, 2021
1,825
1,624
Red Lion
If you are going to mortgage the money or account for lost opportunity for gains, it is much, much worse than that.
Jchonline
600
I would pay $50k more for a 500k house that is air tight and extremely energy efficient. It pays off in so many ways. Depending on where you live it is much more than $100 a month. What about replacement cost for Heating/AC units because they give out sooner (running much more often)? Service calls? It adds up and isn’t as simple as upfront vs electricity bill.
Old_Paint
Dec 5, 2020
2,057
2,364
AL
If it doesn’t rain tomorrow, this ditch will be dry tomorrow night. This was about 20 minutes of rain. Talk about LOUD under a metal roof!
johndeerekim
none, want to buy
Sep 27, 2024
Denver
Jumping in on this older post because I’ve been seeing more folks trying solar setups for pumps, fences, and even small shop power. I’m curious if anyone here has tried pairing alternate energy with their Kubota gear in a real day‑to‑day way. What worked, what didn’t, and was the payoff worth the effort?
MadMike22
Miami, FL
I’ve been easing into alternate energy on the farm by starting small, mostly using it to cut my running costs instead of trying to overhaul everything at once. Even just pairing solar with battery storage has taken some strain off the tractors. On the home side, switching my supply through octopus energy refer a friend made the billing side simpler and a bit cheaper, which helped me justify trying more electric kit around the sheds.
