Happy Block Heater Day!
How many people are happy they have a block heater this season?
  • Dont have one, wish I did.
    Votes: 14 32.6%
  • Glad I have it.
    Votes: 27 62.8%
  • Would not buy another one.
    Votes: 3 7.0%
  • Total voters
Blue2Orange
BX2380 with LA344S & QH05. SB1051. SG0554. BB1248. RB0560, Vassar dirt bucket
Apr 3, 2025
413
290
Bayview Township
What engine oil did they run?
It could be they didn't care about starting conditions because the rental customers wouldn't.
When the well driller wanted to start his rig after it was parked the weekend I asked if he wanted to plug it in first, which he greatly appreciated since there was other setup time involved. Ran some extension cord to his rig and because it was older it helped quite a bit.
I plug my daily driver (gas, not diesel) into a timer and it starts far easier, especially below 10°F; at -5°F it's certainly worth it.
Sounds like my neighbor. He hasn't changed the oil or filter in his tractor. I think this is his 3rd winter. He only had 60 hrs or run time at the beginning of winter. I asked him why not? He use to own a rental company. Same maintenance on his rental fleet. I guess maximizing margins when you sell a lightly in terms of hours used machine.
fmgsr
Kubota, LX2620 - Kubota BX2380 (retired)
Dec 19, 2018
91
47
PA
So I just had delivery of my LX2620. I voted Glad I got one. Although it is not installed as of yet. Got an aftermarket one. Day it went below 10* it was a tough start. So I went inside and ordered one. Never used one. I understand to plug it in at least an hour before using the tractor. But what about leaving it plugged in? will it cook the oil or not? I would guess it has some sought of thermo on it
Spam Bot
Windows Computer
Aug 3, 2024
179
129
Austin, Minnesota/Key West FL
A block heater will heat the coolant for as long as it is energized. The coolant will circulate by convection currents. The heating element is likely 600 watts, so it rarely burns out.
Hugo Habicht
G1900
Jun 24, 2024
1,540
2,230
Ireland
There is probably both types of block heaters on the market, the ones you can leave plugged in indefinitely and ones that may sustain damage.
Check the manual of the block heater, it should tell you.
WI_Hedgehog
Apr 24, 2024
1,130
1,646
Milwaukee, Wisconsin, U.S.A.
The heater is kind of like a coffee pot heater:
  • It costs between $10-20 a month to run if left on all the time.
  • The element lasts "a long time" though not forever, so the less it's run the longer it lasts.
  • It only needs to run an hour or two to do the job.
Unlike a coffee pot they don't (as far as I've seen) have a thermistor (which is often what burns out in a coffee pot) so don't turn themselves off.
Mine was around $100 and it's kind of inconvenient to install so I don't want it burning out, especially since it'll be when it's really cold out.
11,758
I owned a BX25 for five years, and like all tractors sold at the local Kubota dealership it came with a block heater. I kept it plugged in all winter for the first winter but it failed the second winter, so after the dealer gave me a replacement at no charge (which I installed), I added a 50A water heater timer/controller to the barn (now in the garage) and have never had a problem since.
I had rather foolishly assumed that the block heater in the BX had some form of intelligence that would prevent it from committing hara-kiri. It was a cheap lesson in the merits, or lack thereof, of making assumptions. Assumption is code for lazy and there's no way to sugarcoat that.
snoeproe
BX23s
Feb 19, 2026
11
My BX23s came with a block heater. Everything in my area comes with one these days. I use it if I need to use tractor at very cold temps. Mine isn't stored in a heated garage. 15w40 engine oil doesn’t like to move at -30f temps. Engine is much happier starting when I use it. The block heater does nothing to help warm the hydraulic oil/tank however.
GrumpyFarmer
5,175
Does anyone use battery blanket and/or battery pad? (Which is recommended between the two and why?)
If so how are you using, plug in few hours in advance of machine use? Or like a battery tender when’re leave plugged in when machine not in use?
Blue2Orange
Apr 3, 2025
413
290
Bayview Township
The synthetic or semi synthetic stock (?UDT) hydraulic fluid seems to flows nicely under cool conditions. Unsure if it warms up faster than dino hydra fluid. Try a tractor with dino hydraulic fluid in cold conditions if you want to hear your hydra system squeal. So far, haven't experienced hydra squeal using the BX. But, coldest I've had to run the BX is single digits above 0F and I do let the tractor warm up.
Concept Automation LLC
B2650HSDC, BH77
Mar 12, 2026
74
20
New England
I was “trapped’ (sort-of) into buying a Cummins-equipped Ram 2500 last year…. and was pleasantly surprised to read All Cummins had factory-installed block heaters.
(Perhaps this makes-up (in some small way) for that traitorous Grid-Heater.)
Typical of my luck…. the very next version of this engine dumped the hazardous grid-heater and accepted the industry-standard Glow-Plugs. I always seem to get the last-versions of poorly-designed products. :cautious:
Anyway…. during this wide-area-freeze I’ve kept the block-heater plugged-into power….. while I stayed at-home next to the fireplace the entire time. Never even tried to start it. :ROFLMAO:
Still awaiting delivery on used B2650HSDC from Messisck's (adding a BH77). Did NOT have a Block heater from previous owner. So while at this dealer......put one in. I put one in my old Ford 1910 ('86), soon after I bought it in '89. Just used it before the Blizzard hit here in Ct. last Jan.. Sure helps, when you see the snow melting off the hood before you go out side. She will start.
Joisey
Kubota L47 TLB
May 31, 2015
242
166
Wild, Wonderful West Virginia
I had one on my 680 CK Case loader. Plugged in, newly rebuilt engine and it still fired off at 10 degrees F one cylinder at a time. A high capacity blow dryer set to hot and put into the air filter intake tube and let run for 10 minutes made more of a difference than the block heater in starting. The block heater was enough to make the block and heads warm to the touch.
KS Kubota
BX 2350 and stuff
Jul 11, 2020
Nemaha
In my personal opinion and experience as a technician block heaters are a waste of time and money.
If your engine is performing correctly and you have a brand named conditioner mixed in the fuel properly circulated through the sysmtem, you shouldn't have an issue regardless of temperature
When I worked for in the rental industry none of are equipment was plugged into a block heater, some days minus -40 or higher very rarely experience an issue and when there was an issue it was related to engine issue that got resolved
This guy doesn't think like us, lets gang up and run him down. Better yet, stick fingers in the ears so we don't have to hear his blasphemy. (Sarcasm)
It's a poll - opinions were asked for! I'm disappointed in the usually tolerant orange group. Never posted before but have been looking at this site near daily over 10 years and pick up what I can. For the record, don't have one and I'm okay. My stored outdoors BX has failed to start once in over ten years (-20f blizzard) quickly solved with a tarp and space heater.
