Happy Block Heater Day!
How many people are happy they have a block heater this season?
  • Dont have one, wish I did.
    Votes: 14 32.6%
  • Glad I have it.
    Votes: 27 62.8%
  • Would not buy another one.
    Votes: 3 7.0%
  • Total voters
TECH101
Kubota - Bobcat - Caterpillar - Case - John Deere - FARM - CONSTRUCTION -
Mar 8, 2022
75
12
Yes, you are right, the machines are designed to be started at those temperatures and they will if they are not faulty.
But the main purpose of pre-heating the engine, as I see it, is reduction of wear. A Volvo engineer stated that one cold start of an engine (petrol/gasoline) at -35°C (-31F) has the same wear as 15000km (9322 miles) driving with a warmed up engine. Also there is less strain on the starter motor and battery. It also helps starting if compression is not great any more in an old Diesel engine.
I used to have a water heater running with petrol in one of my cars. Maybe this is an option for tractors too because it does not require external electricity.
Well mechanics know that engineers are stupid
  • Dislike
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,237
Ireland
This does not match my own observations. I dare to say it's the other way around. And maybe, with your obviously limited mental abilities, you missed the subtle fact that all vehicles and machines are being designed by engineers and not by mechanics.
And the tests done by Volvo design engineers are facts.
But you are certainly entitled to your opinion.
You have the honour of being the second person now on my "ignore" list, so no need to reply, I will not see it. The ignore function in this forum software is absolutely outstanding.
11,757
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,237
Ireland
Another new member with absolutely nothing of value to contribute.
I could not agree more. Similar to that other guy that was the first one on my ignore list. Everything Kubota engineers did was bad design and he too knew everything better.
But the forum ignore function is really good, makes the offending person disappear completely. Helps reducing blood pressure and avoids nasty, unnecessary arguments that we do not need or want here.
11,757
But the forum ignore function is really good, makes the offending person disappear completely. Helps reducing blood pressure and nasty, unnecessary arguments that we do not need or want here.
I don't use the ignore feature. I've never had a problem with conflict, and I can still learn from someone even if for the most part I disregard most of what they say. I don't need a "safe space".
hedgerow
476
466
Malcolm NE
Back in the 80's and 90's I had a couple semi tractors I installed Espar brand heater {run with diesel fuel} on because the drivers parked the trucks where using a plug in block heater wasn't an option.
GrumpyFarmer
5,214
Well I am a very flawed individual and I am not taking the bait today to respond directly. It’s usually pretty clear when someone is off their meds (or a new dosage) and not sure what they are able to process.
that being said, this is an important enough topic, at least it’s in my manual, kubota thought it important enough to not only have a section on ‘starting Engine in Cold Weather’, but also a section that gives a shout out to ‘Block Heater’….pages 62, 63,64…it even has recommended warm up time based on ambient temperature.
when in doubt, check yer manual.
keep the rubber side down.
TECH101
Mar 8, 2022
75
12
Did all of those diesel engines have working glow plugs? As for working in the rental equipment business, as if any rental company in the history of the world has ever given a crap about the longevity of the equipment in their fleet. It gets used, abused and then sold off with all manner of tax write-off advantages.
Your "personal opinion and experience" don't mean a thing to me and my equipment. I've started cold diesels thousands of times in cold to very cold weather both with and without the use of a block heater. I know which is better and which both I, and more importantly, the engines prefer.
"a waste of time and money" .... seriously?! A block heater is cheap, electricity is cheap, rebuilding or replacing components that have failed prematurely is not. Using a block heater makes batteries last longer, starting motors last longer, glow plugs last longer, engine components last longer etc., but feel free to do whatever you want, just don't pass on your ignorance along to others since that sort of thing is highly contagious.
All the machines were well maintained and serviced correctly, some used glow plug system others used heaters and even air cooled applications. My point is in my opinion you don't need it and 90 % of equipment working in cold temperatures don't have one, its optional.
  • Dislike
Splinters and Sparks
L3902, Pallet Forks, Brush Hog, Box Blade, Post auger
Aug 7, 2025
42
99
I didn't vote..... Don't have one on my new Kubota, and I would buy another one IF I still lived north of the Mason Dixon Line. But these days, if it's cold enough to use a block heater here, then I'd enjoy the work less anyway. It'll still be there when the temps come up.
7,341
I don’t have one on my BX2360.
After 14 winters, I’m okay without a block heater.
Rotella 5w-40 helps a lot, along with a decent battery tender.
BruceMc
BX25D LX2620
Sep 27, 2014
54
122
Fairbanks, AK
About 99% of cars, trucks and equipment around here have a block heater (at a minimum). Standard in this part of the cold world. You don't say where your experience is, but the notion that you don't need one at -40 is silly.
5,449
Again, this is another case of “life's complicated” ……….
My truck (with a 5.9l Cummins) has a block heater…………But I can never remember to actually plug it in, so I have never used it.
It has seen quite a few “cold starts” in it’s day, but has always managed to start.
But admittedly, it spends most of its life in the garage at home. (not heated, but rarely below freezing)
Now my tractor spends its life in an unheated “metal pole barn”, and I usually remember to plug it in.
If I were to guess……(and I am guessing, because I have no way to quantify the next part), the tractor seems to “start easier” (whatever that means).
As for “more wear” on a cold start? That sounds plausible, but I only have 293,000 miles on the truck, so I’ll get back to ya when I wear it out, and let you know. ;) :unsure:
11,757
There are lots of ways to get to 293,000 miles on a truck and lots of different conditions during those miles. Some people have a 100 mile round-trip commute to work five days a week and others might only have a 20 mile round-trip commute to work five days a week. Let's compare those two scenarios without any additional data such as where the owners live, ambient temperature, time allowed for the engine to warm up etc.
Assuming the need to start the truck to leave the house, and when leaving work, the first owner starts their truck 5,860 times in those 293,000 miles. The second owner starts the truck 29,300 times in those 293,000 miles. So one truck sees 5X the number of starts during those miles. If you're a Volvo engineer you can bet that you've got every variable covered and considered in the data set before you make sweeping comments about whether or not a block heater is a good thing.
WI_Hedgehog
Apr 24, 2024
1,130
1,646
Milwaukee, Wisconsin, U.S.A.
As a Design Engineer I'm okay with that statement. I see a lot of designs that I shake my head at, but manufacturing constraints, government regulations (in more than just one country), Warranty requirements, parts availability, assembly constraints, replacement-parts-generating-revenue to offset OSHA mandates, design budget caps, and managerial directives dictate outcome more than Engineers do, Engineers are expected to work within all those constraints and produce a 3-D design, tooling requirements, fixtures, build process...in not near enough time and somehow magically make it affordable.
BUT, the only people who really understand that are Engineers, and they're not afforded the latitude to complain about it, and if they were nobody would listen to their "boring" explanation of....it doesn't matter. Look how complex a fuel cap is vs. how simple they were years back because someone somewhere did something wrong and said the cap was designed poorly, that must be the reason. Or the gas can caused the spill, not the guy not watching the fuel level as he filled the tank--do you think Engineers wanted those crazy gas cans politicians forced on us? For hundreds of years simple stuff worked fine, but now we somehow need regulations to fix all our problems.
I realize the statement I quoted is really meant for the people at the top, the ones that make the decisions, the ones most people are afraid to speak out against because of the difficulty in being heard and resulting retribution. Plus you'd likely need an Engineer to explain what you're trying to say since things are so dang complex.
WI_Hedgehog
Apr 24, 2024
1,130
1,646
"In my personal opinion and experience as a technician block heaters are a waste of time and money." --OTT Member
BruceMc
BX25D LX2620
Sep 27, 2014
54
122
Fairbanks, AK
Snag YT is about 260 miles SE of here (Fairbanks). The coldest I've been out in is mid -70ºs. Hard to be exact, since reading most thermometers gets a little wonky at those temps. Hydraulic fluid can essentially freeze, metal gets brittle and shatters, rubber stops flexing. Even with an open flame you can't light diesel or kerosene on fire until you hold a flame on it long enough to warm up the surface.
LBZ
'20 B2601, '25 GL6060
Sep 17, 2025
47
80
Iowa
Just to point out; over 90% of respondents to the poll are either glad they have one or wish they did.
11,757
Block heaters work well. Parking in heated shops work better.
I have block heaters but don't use them.
You have the ultimate block heater! :)
The only downside to keeping vehicles/tractors in heated shops or garages in the winter, in states where road salt is used, is that corrosion rates are much higher. Most of us don't expose our tractors to road salt though so it's not as big a deal for them compared to road vehicles.
Blue2Orange
BX2380 with LA344S & QH05. SB1051. SG0554. BB1248. RB0560, Vassar dirt bucket
Apr 3, 2025
434
302
Bayview Township
The local Kubota dealer only sells at least the compact and SCUTs with block heaters for a reason. Region ranges from ag zone 3-5. The compact NH purchased in '01 had a block heater. Same dealer. Still working last winter. Traded it in for the BX this past April. I plug it in for at least an hour once the temps dip below freezing. Prefer to have my motor oil flowing nicely at start up. Easier starting. Like a "normal" day. Unsure of how many heating cycles the NH heater had. At least hundreds.
One thing I've noticed with the BX's block heater. If plugged in for couple hours at start up the temp gauge reads at the low end of working temp. The old NH required a few moments for the gauge to move to working temp. Still let the BX warm up for several minutes. Retired. So I have the options not to snow clear until temps a bit warmer. IIRC, the coldest ambient air starting temp was +11F.
