If the wire is similar to my L4740-3, the wire diameter from the 50 amp slow burn fuse to the relay socket is fairly large (guessing 12 awg or metric equivalent). The wire from the relay output to the GP connector located near the oil filter is only approximately 16 awg (at largest). From there to the GP buss bar it is back to the larger size. Not certain why this is the case.The glow plug relay load is heavy wire to a 50 amp fuse. The relay closing wire is on a 5 amp fuse in the schematic of my previous post
The WSM wiring diagram suggests the wire size between the Relay feed and output are the same, but that is not the case on my tractor. Just looked at it yesterday to help the other thread (L3240 won't start when cold) going on about GP operation.
FWIW it is very easy to test the GP voltage and supply time using the single wire connector assuming this model is similar. Disconnect connector and probe for voltage when the key is turned on. If battery voltage at this point everything is generally OK. (Note: GP can not be attached when testing voltage on GP buss bar. Voltage will read very near 0 volts)
Included pictures of the GP wire connector near oil filter and of the slow burn fuses. Please keep in mind these pictures are taken on a L4740.
Good luck with the diagnosis and repair.
