Hi,
New to the forum here, and I'm not very knowledgeable when it comes to diesel engines, or tractors.
Last year the tractor quit running while a relative was brush hogging, he had a diesel mechanic check it out, apparently the fuel injector pump needed rebuilding, (it's close to 30 years old) which we had done. Before the pump was reinstalled we changed the fuel filter and it ran just like it used to. Now for some reason after it runs for about 45 minutes it just quits. You can come back after a day or so, and it will start after much cranking and small spray of starting fluid. After that it runs great and again after 45 minutes of brush hogging it quits again. I just lost my job, and can't afford to hire someone to come look at it, any thoughts on this sure would be appreciated. If more info is needed on the tractor, I will get it and with pictures.
Thanks
Jim
Thanks
Jim
