Generator Starting
DThrash
7030SU MX 4700
Sep 29, 2015
184
Eutaw AL
I've got a generator / welder that I drag out and use about every 6 months. Been having to use starting fluid to get it to pull the gas up. Today I put a outboard motor primer bulb on it. Much better.
3,078
Tractor crack is good stuff!
On gasoline engines mostly…. Kubota warns against its’ use on diesels due to pre-ignition damage issues.
Vince1230
Bx2370
May 13, 2022
130
49
Honey Grove,Pa
Is it gas or diesel? Agree if diesel not good to use starter fluid. Primer bulb was great idea works like fuel pump to inject small amount of gas
4,128
really need to specify WHICH diesel engine as to ether or no ether...
For 15 years I've used 3 seconds of ether for every start of my forklift..winter,spring, summer and fall ,1000s of starts, zero issues
also seen on TV, guys spraying 1/4-1/2 can into heavy equipment and huge water pumps....zero problems...
4,128
The 'ether' I use has a lot of other chemicals (oils ??) in it, specifically to help 'lube' the internals during starting.
I use brake cleaner to kill the nasty wasps and carpenter bees....
4,128
'gas' in tank... WHAT kind of 'gas' ?
All that have ethanol in it, attracts water, which of course sits at the bottom of the tank,so first into the carb.water in bowl allows 'junk' to form, electrolysis to happen, more bad news.....
ideally drain entire system, clean carb, fill tank to brim with PURE gas + stabilizer, run for 20 minutes,shut off gas cock, run dry.
ve9aa
Apr 11, 2021
1,202
975
NB, Canada
Why do people post questions just to have us guess?
We're not all psychics or dentists here. Please don't make it harder for us to help you!
Tell us clearly what machine, engine, model # etc. it is you are referencing for best results.
