SteveBX23 Well-known member Equipment LX2610SU; BH77 May 23, 2021 177 296 63 South Jersey May 8, 2024 #1 Hi. I have a Land Pride FD2560 mower. And it seems that no matter where the oil level is inside the gearbox, the oil will leak out through the vent during operation. What’s causing this to happen? Thanks
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 29,086 5,386 113 Sandpoint, ID May 8, 2024 #2 Try a little heavier oil in the case.
SteveBX23 Well-known member Equipment LX2610SU; BH77 May 23, 2021 177 296 63 South Jersey May 9, 2024 #3 North Idaho Wolfman said: Try a little heavier oil in the case. Click to expand... I'm using 75w or 80w-90 in it now. Try going to an 85w-140?
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 29,086 5,386 113 Sandpoint, ID May 9, 2024 #4 SteveBX23 said: I'm using 75w or 80w-90 in it now. Try going to an 85w-140? Click to expand... I would. If you can drain it all out see if there is any water in it.
SteveBX23 Well-known member Equipment LX2610SU; BH77 May 23, 2021 177 296 63 South Jersey May 10, 2024 #5 North Idaho Wolfman said: I would. If you can drain it all out see if there is any water in it. Click to expand... Thanks. I picked up 85w-140, I’ll give it a shot
GeoHorn Well-known member Lifetime Member Equipment M4700DT, LA1002FEL, Ferguson5-8B Compactor-Roller, 10KDumpTrailer, RTV-X900 May 18, 2018 5,883 3,155 113 Texas May 10, 2024 #6 I wonder if an item such as boltonhooks sells… their axle vents … I wonder if that might help ? Axle Vents - BoltOnHooks LLC Axle vents, axle vent plug, vented plug, vented axle plug www.boltonhooks.com
