Fuel issues.
emadams
BX2680
Oct 11, 2026
CT
My bx is having fuel issues. 2680 with 60" mower deck. While mowing the engine loses rpm almost to stall. Shut off mower it will correct but will still starve while operating. Changed filter and ran fine for a month but problem returned. So I am thinking the in line fuel sending unit or fuel pump. Only 184 hours on it tho. Any suggestions or insight?
4,259
Loosen your fuel tank filler-cap…and see if that doesn’t resolve the problem.
If it does….your cap vent is plugged.
11,285
2 fuel filters and a lift pump
Pull the fuel infeed line off the injection pump and check for good flow.
3,091
Make sure you have the "ticking" sound during glow plugs key on!
These BX machines will run WITHOUT the lift pump working....... with more than a 1/2 tank of fuel.:ROFLMAO:
marrmanu
B2620 3pt chipper, box blade, post hole auger, custom 3pt chain box with hooks h
Jan 16, 2021
160
109
usa
I had a similar problem on my BX2370. I replaced the rear filter and it ran ok for a while and then it clogged again shortly after installing. There was some much gunk built up in the tank that it would continue to clog the rear filter. The tank had to be completely cleaned out. How dirty is the filter second filter you installed. If it as bad as the first one, the problem maybe in the tank.
Mike
