Front mount flail mower from mid PTO
5,595
I can relate to the “off and on” welding outcomes.
I call mine “hammered dog sh!t” , but the sentiment is the same ;) :ROFLMAO:
I guess thats why they make grinders though(?);)
Overall though, nice job on the welding so far(y)(y)(y)(y)
What type of welding is it? I am guessing “MIG"?
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
861
1,599
Baranduda, Victoria, Australia
Yeah, that description also works. Yes, it's MIG.
Interesting that if I count bench grinders and angle grinders I've got 6 grinders and 1 welder. Maybe that's a sign.
Paul Allwood
Jul 8, 2025
861
1,599
More progress - both ends are now welded onto the body and I've made a mount for the gearbox.
I'm going to have to pull the gearbox apart so I can drill and tap new oil fill and drain ports as the ones that are there are at the back and their positions suit a different mounting orientation.
Chanceywd
Mar 26, 2021
881
872
central ny
Some days it is to the point of just taking a break with my welding, before I have to put money in the imaginary swear jar!
If I am trying to do some tig it has to be when the stars are aligned as that really needs my best hand control.
We had a boss in our maintenance group that decided the 5 of us all needed to go a 2 day class on welding so he could learn and be able to judge our ability in regards to our pay.
It was basically a show and tell. I was the only one to do a little oxy acetylene, the instructor couldn't and wanted the others to gather around.
The instructor did some mig and I swear it looked like a caterpillar on the steel when he was done, no penetration and could have been knocked loose with one swipe of a chipping hammer.
The boss said afterwards that he now felt he could do "fabrication" too.
it was a SMH head moment.
Bill
Paul Allwood
Jul 8, 2025
861
1,599
Bill
You sound like a professional welder to me - you've been to a class. I tried TIG on an aluminium roof top box I made for an old LandCruiser about 25 years ago with a proper welder helping me. I've never tried TIG since and it's still a bit of a mystery.
Chanceywd
Mar 26, 2021
881
872
central ny
Not a professional , not certified just trained at the school at hard knocks.
Out of high school I hard a job as a sandblaster/Painter at a welding and fabrication place that that made Braun commercial washing machines for Braun and then they did all the finish work.
Welders there would teach me during breaks on scrap so I had a basic understanding.
A couple years later I bought a new Lincoln tombstone ac welder for my home projects.
Then every job I held there was times I needed to weld i would try some more.
I had to repair some aluminum guards on equipment there so we bought a tig and I kind of learned some from a Lincoln web site. That was a challenge getting that to welding point and if you were not careful and keep moving the puddle would fall thru. From there I was doing repairs on stainless sheet metal some.
Not anything I would brag about for quality but got better as time went on.
I have one at home because there was one for sale used, pretty cheap and I couldn't pass it up.
Still have the old lincoln, a hobart ironman 210, A hypertherm 45 plasma and the tig I think is a miller.
I kind of relate tig to oxy actelyne as far as some of the skill needed. You need to heat the metal to melting point and keep the torch moving or you have a mess. And both can sometimes be done with or without filler metal.
Bill
Paul Allwood
Jul 8, 2025
861
1,599
A bit more progress has been made on the body of the flail mower. I made the adjustable height skid plate with the rear roller as an assembly for over end so far. My first try will have the bottom of the roller about 25 mm below the skid.
I also got the cutter drum back from dynamic balancing. If I was still wondering (I was) about whether the cutter layout that I came up with is a good or bad idea the balancing has settled it - what I've made is a dumb idea. I'll try to explain.
I laid out the cutters with three helixes. The first starts at 0 - the second starts 120 degrees around and 50 mm along from the start of the first - the third start 120 degrees around and 50 mm along from the start of the second. This means that as far as balance goes their starting points are even around the drum at 0, 120 and 240 degrees. But they are offset along the drum by 50 and 100 mm - this is the bit that is causing my problem. The fact that they are paid out as helixes rather than straight lines doesn't help or hinder this balancing problem - it's all in the lengthways offset (apart from other minor variations in tabs, welds and blade mass).
Despite the above design issues it was able to be balanced by the second place I took it to (the first one tried but gave up).
Below is a pic of the weights that were added at one end of the drum - it's similar but diametrically opposite at the other end of the drum.
Here it is on the balancing machine.
Weights added to achieve "balance" (I didn't ask what residual unbalance he was working to):
Without blades
End 1 - 166 g
End 2 - 239 g
With blades
End 1 - 392 g
End 2 - 487 g
Easier to see with a picture....it's a lot....
He showed me the cutter drum running in the balancing machine with the blades attached and I couldn't feel any vibration at the bearing mounts at either end, so I think it will be fine to use.
The large additional weights that needed to be added to rebalance the drum when the blades were added confirms the problem is caused by the lengthways offset of the three helixes. This also means that as the blades wear and become lighter the balance will deteriorate, even if the blades wear perfectly evenly. I don't know how quickly the blades will wear so I don't know how quickly it will get worse and don't really know how much worse.
My plan for now is to get it finished so I can at least test it and see how it performs in cutting our grass. Assuming the rest works ok I'll probably start thinking about another drum layout but this time I'll have balanced tabs and blades diametrically opposite rather than being offset lengthways.
It all makes perfect sense now - yet another good dose of 20/20 hindsight. I'll call it a learning experience.
5,595
I hope it works out for you sir! 🤞 🤞 🤞
I know how it is when you have that much time/money/effort into a project that fails…..(trust me;))
It’s the “Curse of the Inventor”.
(But we still keep at it;):love:🤷‍♂️🤔)
Paul Allwood
Jul 8, 2025
861
1,599
Haha, thanks. Yes it's not the first time and won't be the last.
VinyB (@VinyB57) has some great videos on YouTube on things he designs and builds. One of his favourite sayings is "you're only one grinder away from success".
Chanceywd
Mar 26, 2021
881
872
central ny
I know that feeling, I made a loader bucket out of some bar grating thinking I could sift rocks out of soil. Fail!
I made a backhoe attachment to replace the bucket and come against the thumb to pull at roots.
Instant mangled steel first use!
But the loader bucket still is useful to move dirt as I can see thru the slots when its full where as the kubota sometimes it is only half full and I feel dumb when I travel and dump it.
My lovely clay soil sticks in clumps and doesn't fall thru so it is kinda like a glass bucket!
Bill
Edit, picture of see thru bucket. And roller my son and I made with worn skid steer tires. That works quite well smoothing the stone driveway after spring grading.
With me the trial can become permanent and never gets painted.
Paul Allwood
Jul 8, 2025
861
1,599
Bill
Sounds like quite a clever design on the see through bucket. Maybe you should have patented the design before you shared it here ?
I reckon anyone who has had a go at making something a bit non-standard would have had something that didn't quite go to plan. It used to happen often at work even after loads of modelling, testing, trialling etc. Always something to catch us.
Paul Allwood
Jul 8, 2025
861
1,599
Bill
What didn't work with the bucket ? Were the gaps in the grate too small ?
Nice roller.
Chanceywd
Mar 26, 2021
881
872
central ny
Nice roller.
I figured just a little shaking and the dirt would fall thru but it didn't.
I have some experience where 120vac motor vibrators were attached to plastic resin hoppers to keep flowing.
They make them in hydraulic and 12 volt. I may try one of them one day or build a screen that I could dump a scoop on. Just down on the project list right now. Spent the day working on the woodshed.
Hope you had a good day on your project!
Bill
Paul Allwood
Jul 8, 2025
861
1,599
Not sure if I'll ever get this mower finished, but I did make more progress today.
I made some bits to hold a sleeve onto the gearbox input shaft to bring it up to 1-3/8" 6-spline. This included drilling a hole into the end of the hardened gearbox input shaft. To do this I sharpened cutting edges onto a carbide tipped masonry drill bit, ran it slow in the drill press with lots of cutting oil. I got the hole through from the end to the existing cross hole, but the drill bit didn't survive.
The gearbox is fitted - I had to move it across to get the input shaft in line with the PTO shaft attached to the bottom left side of the front diff housing. Also had to make a longer gearbox output shaft because of this offset. I originally forgot about this and had it centred (boxhead).
Fitted the side skid plates and the rear roller.
And for bonus points, the roller even rolls.
Paul Allwood
Jul 8, 2025
861
1,599
I'm going to try to run the mower on the rear roller and front caster wheels with the side skids just above flat ground. Aiming to let it follow the contours with no input from me.
I've made a start on the caster wheels - here's the first prototype.
Chanceywd
Mar 26, 2021
881
872
central ny
Looking good Paul!
I like that little level, I have one I stick on the grill guard when I am trying to grade the driveway.
I have another one I think is a Klein that had a magnetic base and a built in light that was really handy when I would run conduit at my job.
But yours the bubbles seem to really show better than mine.
I may have to search out and buy a another one!
Bill
Paul Allwood
Jul 8, 2025
861
1,599
I made two caster wheels for the front of the mower plus mounting frames. Also got it all tack welded in place. I'm happy with how it's looking.
I was planning on making a couple of arms that would pivot from the from bumper and attach to the mower frame to push it along. This would need the loader to be raised just above the mower. No problem with that except that it badly restricts forward visibility
near the mower.
Since improved visibility was one of the main reasons for putting the mower at the front, I'm gonna need a plan B. I'm thinking I could use the SSQA to mount and pick up the mower....maybe this should have been my plan A ?
Getting the PTO shaft through will be tight and may need some adjustments to my SSQA setup. I haven't looked at this closely enough yet to be sure. I might be able to move the tube or tubes that connect between the two sides of the SSQA up so that they are above the PTO shaft. This might need to be done in conjunction with converting the loader to mechanical self-levelling which will also remove the central hydraulic cylinder (another project still on the list).
I'm still keen to push the mower along on the rear roller and the front caster wheels so it can follow the ground contours without my input. If it works, this seems like a pretty relaxed way to mow.
One option would be to use float in the loader valve to look after the up and down movement, with some sort of pivoting linkages to look after side to side.
Another option is that I remove the loader for mowing. When I made the loader I made it removable but haven't tried removing yet.
I'm interested in any thoughts anyone can throw my way.
RMS
Sep 26, 2021
320
696
Buckfield Maine
Hard to tell from the pictures, but could you attach/fabricate an SSQA plate on the back side of the mower that would hit a sweet spot that would have your loader frame high enough that it misses the pto shaft but is not too high to restrict your sight?
I'm not a fabricator, but I have been enjoying following this thread.
Paul Allwood
Jul 8, 2025
861
1,599
Thanks for the suggestion - maybe. I'll have a look when I get back to the shed.
