Front mount flail mower from mid PTO
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
858
1,595
Baranduda, Victoria, Australia
Could you mount a slip clutch to the existing stub shaft and just have one universal joint involved? In other words just eliminate the sliding part of the shaft completely?
But I really think you only need around 100 to 150 mm of overlap on the shaft. Why are you thinking of 400 mm total?
Of course you need some extra space for the shaft to collapse but your mower seem rigidly mounted at the distance shown by your picture above. So maybe you just need the shaft short enough to fit onto the stub on the mower and then extend into locking position with 100 mm overlap remaining.
Thanks Russell. Given that the mower will need to move up and down, a little sideways, and tilt up and down, how would it work with only one uni joint ? I'm not sure I understand your suggestion - how would the slip clutch help me ?
The 400 mm was purely my guess at the minimum length of overlap to stop the shaft wobbling at 2500 rpm.
Edit: After some google searching this morning it looks like the most common minimum PTO shaft overlap is 6 inches as you suggested, not 14 inches as I had guessed. I'll need to have a more careful look at the range of motion for the mower and what this does to the PTO shaft length so I can maintain the minimum overlap of 6 inches and sufficient clearance to not bottom out. I'll also lower the linkages pivot points where they attach to the tractor and the mower to get them closer to the height of the PTO shaft to minimise the length change as the mower goes up and down.
Paul Allwood
Jul 8, 2025
858
1,595
Tractor time with Tim had a problem with the PTO turning backwards.
Thanks Jeff (?). Every time I make something I wonder if I'm doing the right thing. It always seems like a great idea at the start, but then I always start thinking of other ways I should have done it. So I really like that he makes a good case for front mounted mowers.
I also like the shaft that goes from the crankshaft to the front PTO/3 point assembly. It looks to be about the size I could use.
Paul Allwood
Jul 8, 2025
858
1,595
Thanks - something that length to suit 1-3/8" 6 spline shaft at each end would work nicely. But at over $500 I'll start by shortening the shaft I have. Once I've got all the bits in place properly I'll check the movement and range of motion properly. Then I can work out how short I can adjust the linkages and the drive shaft. I don't think it will be too bad if the mower ends up a little further out than it was when I tested it a couple of days ago - it was easy to maneuver and I've still got hydraulic steering to add.
I'm interested in your thoughts on another idea....I'm thinking of using a hydraulic cylinder in place of the diagonal link to give me side shift. I do have several trees to mow around, but having never used a front mounted mower I'm not sure how useful this feature would be.
Paul Allwood
Jul 8, 2025
858
1,595
And another suggestion.
What about plates mounted on the tractor that have vertical slots cut in them, two plates per bracket with a plate on each side of each bracket. The mower brackets could mount to the plates with pins, and the mower could move up and down within the limit set by the length of the slot.
This would also limit side to side movement if the plates are made strong enough.
Thanks for the suggestion. I can see how this could work well for up and down movement. But I can't quite work out how to make it work if one side goes up and the other side goes down at the same time as preventing side to side movement. Any further suggestions ? The bar has been set pretty high by RWS, but I'm often better at understanding pictures.
Edit: I think I found something that might be what you're describing - sorry it's the wrong colour.
A bit closer. It looks like the but in the red circle pivots up and down, and the slit 3 and pin in the white circle allows one side of the mower to raise while the other side lowers.
The interesting thing here is that they have the linkages pivot pretty much in line with the PTO shaft pivots....that's what I've been working on today.
Paul Allwood
Jul 8, 2025
858
1,595
This afternoon I was just sitting, looking at the front of the tractor, thinking. I was thinking that I needed to check the clearance between the mower PTO shaft and the front left tyre. Turns out that on full right lock the front left tyre just impacts the uni on the PTO drive shaft to the mower.
One of the full lock limiting bolts before and after adjustment - 2 threads was enough. Same on the opposite limiting bolts on the other side.
About 1/2" clearance between tyre and PTO shaft uni joint after adjustment.
Another crisis averted.
Chanceywd
Mar 26, 2021
881
871
central ny
You said you would like to see my side hill mower. I took a couple pics yesterday but forgot to take a view from behind or in front to show the down hill or up hill angle, only have some from the seat!
First one is where my hitch attaches, One long pin and attach the hydraulic cylinder.
Second is mounted and attached to the mower.
Next with raised and using my foot I show a little of its movement.
Next is mowing the hill when it is rising away from me.
Then mowing the slope below me.
And last is it raised while I turn and go back to the lower side.
I used to do this with a push mower and a weed wacker but old age and arthritis made me want to do easier.
It only takes a few minutes to hang the hitch.
Bill
edit, a couple pics showing the hitch and the angles when cutting.
Paul Allwood
Jul 8, 2025
858
1,595
Bill
That looks great. Do you use the hydraulic cylinder to raise and lower the arm that has the mower mounted to it, then let the mower pivot at the end of the arm to follow the ground ?
Chanceywd
Mar 26, 2021
881
871
central ny
Yes that is it in a nutshell.
The mount I made that hangs on the red frame on the tractor, that has a repurposed front wheel drive bearing and hub assembly on it. Then the 2" square tubing is mounted to that.
The hydraulic cylinder is fastened to the short end of the tubing.
When I put it in float it follows the ground nicely, I can even back up with it.
I thought about hinging the bar in the middle with springs so if I bumped something there would be a place to give but how and where I use it I haven't needed it yet.
I have to say around here the highway departments use something along this idea to mow along the roads and that is where I got the idea from.
And as usual I never seem to go from trial prototype to finish paint with the mount!
If the day is nice today maybe I will mount it again and take a couple pics of it from front when it is in mowing position.
Bill
Paul Allwood
Jul 8, 2025
858
1,595
Bill
Ingenious.
Paul Allwood
Jul 8, 2025
858
1,595
I'm including hydraulic side shift in this flail mower - currently working out how far it can move. It seems to be limited by the maximum angle of the PTO shaft uni joints.
A Google search suggests a maximum angle of 17 degrees for continuous operating, and 25 degrees for short bursts.
Do these angles sound reasonable ?
Paul Allwood
Jul 8, 2025
858
1,595
I finally finished making all of the bits ready to give it a mowing test this afternoon. The last thing to make today was the belt tensioner running on the back of the 2 B-section belts.
It's set up ready for adding a hydraulic cylinder to allow it to be offset. The cylinder will replace the piece with the orange stripes.
Since I first tried pushing it around with the tractor I changed a few things.
I moved the gearbox 8" to the right and moved the whole mower 8" to the left. This means the left side cuts about 10" outside the rear left tyre and the right side cuts about in line with the outside of the right rear tyre. The hydraulic offset will allow me to shift it 8" to the right. Necessary ? No idea.
I moved the mower forwards by about 14" - wanted to make sure there's enough PTO shaft overlap.
I lowered the points on the tractor that push the mower so that the pivot points are pretty much in line with the PTO shaft. My theory here is that this will minimise the length change of the PTO shaft as the mower moves up and down. I did the same thing with the pivot points on the mower for the same reason.
Made a new angle brace and moved it's attachment points to keep it clear of the PTO shaft and so it also clears the PTO shaft when the mower is offset 8" to the right.
Pretty happy with testing today mowing some grass. Also mowed over a couple of rough patches and a couple of piles of small sticks that I wouldn't have done with the finish mower.
Here's a few pics of the setup.
Here's a few pics of some nice cut grass.
To be continued.
Paul Allwood
Jul 8, 2025
858
1,595
And some videos of the test run....
Turning uphill - yeah, forget about it.
Jayse approves - the new cut grass is just right.
So what did I find out ?
It mows really well. No clumping along the exit side as with the side discharge belly mower. I didn't notice the mowing load on the tractor and this was about as long as it grass normally gets. It went well when I went straight into a section of long grass and went easily over piles of small sticks.
The front caster wheels worked really well.
The steering was terrible. Steering downhill was ok, but steering uphill was hopeless - much worse than the first test when the mower was close to the front wheel. I don't know if this was caused by the mower being 14" further forward and having to push the further out rear roller across the grass, or the additional weight of the cutter drum. Perhaps a bit of both.
I moved the mower further forward so I could fit the PTO shaft, but I think I went too far. I think I'm going to need to find a way to shorten the PTO shaft quite a lot, then shorten the links between the tractor and the mower (easy enough) to get the mower back closer to the tractor. For the PTO shaft - maybe shorter, more compact uni joints, maybe I need to make this too ? I'm also wondering if 2, 3 or 4 caster wheels might be better at the back instead of the rear roller. If I did this they would need to be smaller than the front front wheels, but I'm think 4 could work too provide anti scalping at about 16" apart. I'm thinking it would be easier to push caster wheels sideways than the rear roller.
Another problem - the cutter drum runs beautifully smoothly up to about 2,000 rpm. Above this the vibration starts and is not so good at the target speed of about 2,500 rpm. I'd already sort of decided I'm going to make a new cutter drum. Now that I know it mows well, I'll definitely do this.
Also now that I managed to get our grass cut, I've bought myself a little more playing time.
Chanceywd
Mar 26, 2021
881
871
central ny
Looking good Paul!
You might be on to something with adding caster wheels.
I have thought additional wheels on my rear brush hog might be a help too.
While you were testing it did you try helping the steering issue using the left or right brake pedal?
I find that when plowing snow with my 8N that is something I am always needing to do when the front blade is angled. With the kubota always need to when back dragging with the loader.
Bill
Paul Allwood
Jul 8, 2025
858
1,595
Thanks Bill. I didn't even give the independent rear brakes a thought. I'll give it a try tomorrow - thanks for the suggestion.
3,170
Perhaps the caster wheel carrier needs the axle set farther away from the pivot point? That would make it rotate in the rotational pivot easier.
Or chain the mower to the FEL and take some weight off the mower and onto the front wheel.
Or get really fancy and add your power steering to the tractor and add hydraulic steering onto the mower!
Paul Allwood
Jul 8, 2025
858
1,595
Thanks Russell.
Adding a couple of chains from the FEL to the mower to shift some weight from the mower to the tractor front wheels is a great idea. I'll give that a try today and report back.
Haha - hydraulic steering on the mower would be fancy. Are you thinking a couple of drive wheels on the mower and also steering them ?
Paul Allwood
Jul 8, 2025
858
1,595
@Russell King I tried your suggestion of taking weight off the mower with the loader to transfer weight to the front wheels of the tractor. The difference was like night and day. Without it I couldn't turn uphill. With it I could turn uphill like the mower wasn't there. Thanks again for the suggestion.
@Chanceywd Bill, I also tried using the independent rear brakes but it didn't seem to have much if any effect. Not sure if this is a limitation of the idea or the operator.
