Front Lift Arm Pins ?
tennred
L4802HST
Apr 15, 2026
West Tn.
To lubricate the front lift arm pins ( not implement end ) it looks like you remove bolt that holds pin in. Is this correct? I was going to put dry lube on them. (On L4802 HST)
Caden
1979 B7100
Apr 16, 2026
329
188
Morning
I am a little confused by your post. Are you referring to pins on the FEL? Or lift arms on 3ph?
If its on the FEL I very much doubt they need to be removed and you should use regular grease. Should be a fitting somewhere.
Bee-Positive
Nov 16, 2022
1,180
1,088
Amsterdam, NY
For the FEL - the front lift arm (boom) pins are lubricated by the grease fittings on the boom lift cylinders.
11,243
You really don't need to lube the front eyes or pins.
But if you so desire a little squirt of penetrating oil will do.
