tennred New member Equipment L4802HST Apr 15, 2026 5 0 1 West Tn. Jun 28, 2026 #1 To lubricate the front lift arm pins ( not implement end ) it looks like you remove bolt that holds pin in. Is this correct? I was going to put dry lube on them. (On L4802 HST)
Caden Active member Equipment 1979 B7100 Apr 16, 2026 253 126 43 Virginia Jun 28, 2026 #2 tennred said: To lubricate the front lift arm pins ( not implement end ) Click to expand... Morning I am a little confused by your post. Are you referring to pins on the FEL? Or lift arms on 3ph? If its on the FEL I very much doubt they need to be removed and you should use regular grease. Should be a fitting somewhere.
B Bee-Positive Well-known member Equipment BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box Nov 16, 2022 1,075 999 113 Amsterdam, NY Jun 28, 2026 #3 For the FEL - the front lift arm (boom) pins are lubricated by the grease fittings on the boom lift cylinders.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 36,153 11,078 113 Sandpoint, ID Jun 28, 2026 #4 You really don't need to lube the front eyes or pins. But if you so desire a little squirt of penetrating oil will do.
tennred New member Equipment L4802HST Apr 15, 2026 5 0 1 West Tn. Jun 28, 2026 #5 I was referring to the 3 point hitch, I should have been more specific . Thank you.
