For Cleaner Air on L Series
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
I purchased a new L2501 HST in July. On this forum I learned of a second air filter which may be installed INSIDE of the existing air filter to remove any particles the first filter missed. This filter may not be in the L2501 parts list. The local mechanic told me in my case it is unnecessary - relatively low use tractor. He only recommends the second filter to farmers using the tractor in dusty conditions all day every day. At under $20 I decided it was cheap insurance and purchased one anyhow. They are a no brainer to install. You may put it into the existing filter then replace both at once. You may install it then place the regular filter over it. The air filter cover may be a bit more difficult to replace due to the added pressure against it but if the housing cap is properly aligned with one lip going inside the other it will pop into place. The Kubota part number for the filter is TA040-93110. The description is Element Assembly. Although not included with the L2501 they are the same filter as some of the larger Kubotas use.
Fordtech86
L3200
Aug 7, 2018
4,866
5,718
Pineville,LA
Install the inner filter first into its place in the housing and then install the outer filter. If not the inner one may not properly fit rendering it useless.
Fordtech86
L3200
Aug 7, 2018
4,866
5,718
Pineville,LA
And if the inner is properly installed first then the outer there shouldn’t be any extra pressure needed to install the housing cap.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
Thanks for the tip. I think the extra pressure required may have been because I hadn't gotten the inner filter on quite far enough. I'll take it apart and try again.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
When you put the filters in do a slight circular rocking motion. Not twisting but rock the filter just a little as you push it in. You can feel it seat when you do this.
