Fixing hole in side of block
Status
Not open for further replies.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,050
1,489
Pittsburgh
In fuedal Japan, assassins were anathema. The bushido code of honor expressly forbade action against one's enemy without notice or forewarning. Doesn't mean ninja weren't cultivated and deployed.
Sun Tsu disagreed, I'm sure.
Hugo Habicht
G1900
Jun 24, 2024
990
1,397
Ireland
Hmmm... did not know that, but using a Japanese tractor probably requires following this code of honour, so thank you very much for pointing this out ! (y)
I trust that internet is permissible nowadays.
So I herewith give notice to my lawn that I will attack it with my Kubota (without hole in the side of the block) in the next few days (weather permitting).
p.s.: in fairness, I think Joe always gives notice to his poor tractor before he attacks it with a blow torch or sledge hammer ...
2,464
this is factory image of your loader, you can see they do have a beam connecting those 2 point
problem: if you put a beam there, you won't be able to open up your hood, it block it
maybe: forget the hood, do you a big ol magic trick putting a beam there, let it marinate
@joesmith123 - note that bar across the front is ”easily“ removable so the hood can open. I think you could at least install something similar and see if it helps your loader.
And I still say that you should spend money on an electric welder or hiring someone instead of on oxygen and acetylene.
But you should look at this site and watch #18 “welding the big ring” for another method of welding that you can adjust to your needs. Watch all of them really- they are a good look back at early industrial days. I am amazed at how long these people can swing a sledgehammer and not get at all winded! They were fit for the work!
3,287
@joesmith123
So very true. BUT I get the impression that Joe is off the grid and relies on solar or something for his electrical power. Could be wrong here, not sure. Actually don't even know what planet Joe resides on, to be honest.
Pretty sure though, if Joe had an stick welder, he couldn't make welds worse than what he is doing with gas! And the welds would improve over time, and it would take one minute to do what he is doing in 30 minutes now.
BUT, and it is a BIG BUT, if you don't have the power to run a stick welder, you are not going to run a stick welder.
Just the way it appears to me after following this thread from the beginning.
Workerbee
Zd21
Mar 1, 2020
321
185
MN
Get a gas driven welder, of course thats worth more than all of his tractors, but he could run it.
Chanceywd
Mar 26, 2021
744
687
central ny
I had a wire welder I bought years ago from I think maybe from tractor supply.It was a 110vac or with cables that came with it you could run off grid on 24 dc , 2- 12 volt batteries in series. I think it just just bypassed the whole internal ac power supply. I would think that there must be something like it still out their. I gave it to a relative when I bought my Hobart 210 Ironman .I remember also seeing kits to use an alternator for welding too.
So there is ways besides ox/ac.
Bill
Donystoy
Dec 10, 2013
690
324
Binbrook, Ontario
Does Joe have access to electric power to run a welder? I would look through previous posts but that would take a year. Even a basic A/C welder would work better. I have nightmares if I read his posts before bedtime. Otherwise, I commend him for staying with it with limited resources.
3,287
Good luck getting Joe to answer that question. I believe in previous posts he indicated he was off grid...
C'mon Joe! Help us out here!
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,495
2,087
WestTn/NoMs
We don't know, but he has enough power from somewhere to run a grinder so I think he could run one of the new IGBT? welders.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
yes, what might happen: put you a beam across with big bolt holding it, then when you want to play with your hood, take out the bolt instead of magic trick
hahahaha, right?
yes, off grid, there is solar, but there is a dinky inverter that won't handle running more than a small air compressor
everything you've seen has been done off grid (no electric, no water, no sewer, barely any internet)
woah, I would pay big $ to get the complete comprehensive reasoning behind this statement, because
I know what I feel, and I can barely bend down to do anything from the burden/thinking/task/whatever
woah, witness you old footage from the steel capital of world, notice you the people are way different acting/being than they are today
study you them, who were they? And why are we not like them?
too funny, you musta heard your Japan robot mumbling something about fixing you that puddle, but you were lost in boxcar and didn't hear her
yes, according to @hagrid , she aint no assassin, she a ninja
Your best friend, acetylene, call you screaming earlier about something
he say: why is your thread telling you to not use me when I hold your robot tight and nothing is breaking?
Your response: I tried to tell them that you are my only friend, but they insist to go with another method
woah, your best friend mad at your thread for doubting his power/result
unbelieveable
more ninja talk you forgot to add:
you can even put it in low gear, turn the wheel completely one way, reverse with the bucket down, and she will do a 12 foot circle, cutting DEEP in your earth, boring that high point down, zero input from you
your mind always wondering about this new found/rediscovered trick, and what it mean for your earth shaping
you find your mind wondering which way it is pushing dirt, most of the time, you do not even have to think, your Japan ninja will do the thinking for you
you tried to "think" about solving that puddle for 2 week, then your Japan ninja do the reverse spin trick on that puddle area and solved it without you understanding how
woah, 60 page into your thread, and narrative telling you to stop thinking,
that's actually unbelievable
Donystoy
Dec 10, 2013
690
324
Binbrook, Ontario
Because of what you are going through to get this tractor repaired. If you have diesel to run the tractor it is too bad that there is no diesel driven electric welder available. The cost of the gas for the torch must be expensive as well.
In Utopia
L175 FEL
Apr 21, 2013
646
169
Utopia,Tx/Pasadena,TX
He's used an angle grinder before, don't know if it's corded or battery powered. If battery maybe he uses solar to charge it up.
3,287
Perhaps a set up like this would be workable for Joe? Could be fabricated at home, and a serviceable welding helmet purchased from Harbor Freight perhaps? Need full face and skin covering if you don't llke serious sunburns...
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
busted fel valve magic trick
this is the 6-7 time now that your fel valve magic trick bust
bring you out the big gun, learn you from the busted front support (where you used a wheel spacer)
plan you out to weld a big ol steel bracket (not household)
you see the shear in your double household bracket
prop it up, weld it together, lower the high point, then
melt your big bracket on its end to spread the stress area
first, melt you everything together, then melt the big bracket spanning across to spread stress
for those wondering about the budget so far in magic trick:
total spent on gas so far about $280 on two fill up of magic gas, list all the magic trick you remember:
6-8 time on the busted fel valve
2-3 time on the busted front support (wheel spacer)
1 magic trick on a big cracked support
8 hours of magic trick on your bracket/fender bracket
all the plumbing magic tricks (to fix the leaky hydraulic line 20-25 pages ago)
other magic tricks not on this thread: fixed a gate, fixed your busted exhaust, on and on)
meaning: the cash value of all that magic if you woulda hired someone would be around $3000
there is more magic that you forgot about
what about the magic of your heart reconnecting to your mind? how much cash is that worth?
get back to your magic enough with the small talk
plop your bracket where you want it
melt you one side of your bracket to your fel valve
use a block to hold hydraulic lines away from weld area
try your best to make it stick on its ends, most importantly
feel your magic gas running out, then point you that flame even closer with your heart
out of magic gas, that might be the best you got it
on today episode of hillbilly science, will your 1/4 inch steel bracket hold your
busted up fel valve that have you melted: big bolt, 2 bracket, etc
that have tried to make it hold now for the 7th time
unbelieveable
yes, your quarter inch steel bracket held your busted fel valve while you shape your realm
more molten-land leveling connection:
woah, they really are synonymous, the land leveling and the molten control
spend hour and hour playing with the molten,
hop on your tractor and level your realm
the same way that you swing that big ol steel blade planing out your existence,
similar tactic used when you melt steel into one entity
two wing of the same bird
Chanceywd
Mar 26, 2021
744
687
central ny
They make a spool gun type that works off batteries that way to but a bit pricey over $1,000 new.
Some on ebay used for $400-500.
Jim L.
870
172
Using gas for heat is essentially what is shown in the video. Note that besides the hand hammers, the ring is moved under a drop hammer.
Since the tractor welds seem to be breaking at the weld line maybe try using a ball peen hammer when still hot. It would compress the material for strength. Used to be known as blacksmithing.
jaxs
B1750HST
Jun 22, 2023
990
763
Not to be confused with joesmithing. 😬
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
japan ninja shaping earth
woah, reverse tricking working great, got you rid of puddle pretty much
keep you studying why that reverse trick work so good, imaging the motion of the dirt
soon make diagram about why it plane your realm so well
electrical situation: this is your dinky chinese inverter that ran your whole shop that fixed your robot, all powered by the sun
it has a mind of its own, turn off randomly, turn on somewhat reliably
it has to be rebuild once with a new motherboard, they're junk
it really is true: when that reverse trick plane out your realm, with zero input from you
in that state you heart is healing, the comfort of zero input from you and actual result/cash/gold
witness you the result of:
low gear, steering cut one way entirely, about a 20 foot diameter of your crop circle leveling target
here's a receipt of you:
doing your ninja reverse leveling trick, with no hand on the steering
enjoy your realm being shaped with free hand to do whatever
you check on it once in a while just to make sure you aint gonna hit nothin
you can do this in high gear with about a 30 foot diameter leveling area
icing on the cake: you were playing with your device, not looking at your realm,
5 minute later: you look at your realm and say,
woah, it leveled out my realm with me looking at it i was doing something else
there is nothing more hillbilly than what you just witness
woah, show you what you did:
high gear, 2 wheel drive, cut it pretty tight, 75% throttle
maniacal ninja spinning big steel blade lugging crazy amount of earth,
do this for 30 minute, and your dizzy coming off your japan ninja robot,
your about to fall from dizzy, but no, your ninja robot make the realm so plane, that you dont fall
this clip singlehandely just RIPed the modern skid loader:
here you are in high gear 2 wheel drive, spinning your ninja with about a 24 foot diameter
the clip is in real time, witness your realm being planed, and both hand free
rip skid loader
(this lesson sponsored by hillbilly trust fund)
in the diagram you have a low point surrounded by high point
the blue arrow is your big steel blade swinging direction
this is why your realm plane out with no effort from you
no matter what, doing these strides push dirt into the low point eventually because gravity
woah, with gravity and your japan ninja trick, solve you major puddle problem while your hand are free to do whatever
zero thinking, barely looking at it
more hillbilly science:
imagine that the dirt is water, your blade swinging it in this drain like fashion,
how water go down a drain, in that circular motion,
you are using this hillbilly logic to get rid of your puddles from on
woah: your blade swing dirt like water down into the drain/low point
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
563
569
Lake Almanor, Ca
It’s ALIVE!
Mostly😎
OP…this thread will go down in the history of this site. Not exactly sure what for…but HISTORY damnit!
Status
