finally.....about to move in...still researching
11,311
Why is there a clutch? specifically when would you use it on an HST?
It's a safety disconnect and for PTO operations.
The placement of the brakes on this tractor really sucks, why is it right over the top of the HST pedal? weird, could get used to it, just really odd placement.
Yes it's odd, but on an HST it's rare to even touch the brakes ever.
Can you just get a grand L pedal and attach, or are the mounts different for one reason or another?
I'm going to say, most likely not an option.
I want the R4 tires. but should I get the rear wheel spacers , how much do they actually move the tires out?
Depends on what size spacers you get there is 1/2" all the way on up to 8"
the hydraulic flow specs on this tractor aren't great, do they make a 3rd function for this tractor (not listed on kubota's site) or will I have to go aftermarket? do they make a low enough flow to be able to use a skid steer quick attach style post hole digger (prefer the ability to reverse the auger if necessary)? best I've found was a 6 gpm min flow rate.
Your not going to be able to "power" any motor run attachment with a third function on that tractor, no where near enough flow, most third functions, even aftermarket are only good for cylinder movement.
You can get a Power pack to run like a auger or a blower but they are not cheap, they are a PTO pump, tank and most of all a cooler as the fluid will get very hot from the work.
virginiavenom
373
Sherman, TX
when you say safety disconnect, do you mean you pretty much have to clutch to start it, but that's it? and clutch to engage and disengage PTO? so it's basically a PTO clutch?
roger that on everything else. so better off getting a normal 3 point post digger? so next question, how do I put down pressure on a post hole digger without a top N tilt safely? or regardless of ground conditions should a good auger do it minus rocks/roots etc?
virginiavenom
373
Sherman, TX
Looks like the Kubota rear wheel spacers are L8787 and move each rear wheel out 1". Price from "Build My Kubota" is $233. http://www.kubota.com/configurator/BuildMyKubota.aspx?pgId=1&bmId=1060&sId=125
Down pressure on a 3pt hitch is separate from hydraulic "top N tilt", and only available on a few tractors.
A salesman told me the clutch on the L2501 is used when engaging/disengaging the PTO.
I thought the top N tilt gave you hydraulic cylinders that would tilt the top link or push it down.
Grouse Feathers
Feb 16, 2015
1,022
11
Lovells, Mi
I think as the top link pushes down the 3 point hitch will float up. The easiest solution may be to add weight to the post hole digger or 3 point hitch.
Dalroo
MX4800DT
Aug 24, 2015
136
Brookesmith, TX
A suggestion on your decision process. If possible, rent tractors in the size range you are considering and then determine which is the best fit for your needs. I did this and ended up with the MX4800 simply for the added weight, and ability to pull larger implements.
I'm originally from Ada and know your part of the world well. Those boulders are a pain, and yes, they appear to grow out of the ground! Almost like shark's teeth, when you extract one, another replaces it!
