Filter cross reference
Creature Meadow
Sep 19, 2016
1,063
135
Central North Carolina
I looked for 10 minutes on the Wix site and Baldwin site did not find anything.
Coleman equipment has OEM parts and the one you are looking in stock. Should you want to purchase OEM, price was about $38.00.
OlFerguson
4440, 1120D
Jun 1, 2017
183
11
Usually Baldwin has many filters for most machines . But for those types of filters , just as easy to stock pile some from the dealer .
Bonaro
L275DL
Mar 30, 2017
103
Olympia, wa
I saw the listing at Coleman.
I was hoping to find one locally and immediately available without paying $36 for a $6 filter.
rancher1524
Tractor LX4020 B3350SU
May 11, 2016
106
20
Evans, Washington
You get what you pay for. A cheap filter is just that. Cut it in half and a OEM Kubota filter and you will see the difference. If you wanted cheap filters, you should have bought a cheap tractor.
JohnDB
M4500DT
Jun 9, 2018
378
NZ
If a $6 filter is as good as a $38 filter, I guess a $2 filter is also in the running. Be aware that cross reference charts usually only show what filter will physically fit - there's no guarantee it will provide the same or better filtering performance than the OEM. Yes you are paying for the Kubota brand - at least some sort of assurance that the filter you buy will actually have the right performance for your tractor.
3,077
The Kubota spin-on filters are reasonably priced, IMO, and are a good value for their quality.
I use “cheap” filters on some equipment (such as my Sear lawn tractor with a B&S engine...the Sears or B&S filters are priced at $11-$16 and the SuperTech/Purolator/Motorcraft versions are all less than $4 at WalMart.).
I don’t think you’re going to save a bunch of money over the life of your tractor using aftermarket filters instead of the genuine Kubota products.
The hydraulic filters operate at very high pressures and a cheap aftermarket product in that location is not a good idea, IMO.
kubotafreak
Sep 20, 2018
1,022
375
Arkansas, US
At least your not HST, right? I think you would be better off leaving an oem filter on past the maint. schedule than putting an alternative on there. I believe Baldwin or Donaldson may be the oem manufacturer for some of the Kubota filters if you feel so compelled. Heck search ebay with that oem number. I find some overstock every once and a while.
Bonaro
L275DL
Mar 30, 2017
103
Olympia, wa
FYI - I researched this pretty hard and found no aftermarket filter alternative.
I discovered the local Kubota Dealer had one on the shelf for my 40 year old tractor for $37
...sold
