FEL pallet forks....
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
WOW
If you have a FEL and don't have a set of pallet forks, you are missing the boat.
Today i received my Titan 42" pallet forks for the JD "quik-tach" system. I ordered these on Monday, pretty fast shipping, seeing as it is such a heavy item requiring freight delivery.
After unloading them from the semi, I promptly set to assembling and installing them. Within 4hrs time, I had moved/relocated/organized, so many different items around the place, that i felt compelled to make this topic stressing how i think they are probably the most versatile attachment you can stick on your FEL.
Installed a new seat too and put a couple washers under the front mounting points, to shim it up some. The old seat was super slick and i was always sliding forward.
Obligatory pic....
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
323
Mobile, AL
I bought the UA 48" forks from Titan. They are quite handy. I moved a bunch of brush and piled it up against a tree line this past week. Some of the brush didn't slide off of the forks so I rolled the forks all of the way down and shook them. In doing so I hit a pine tree and caved one side of the guard in. My mistake and a lesson learned.
BX Woody
BX1880, FEL, MMM, Bagger, Snow B
Feb 10, 2018
22
Yes they are handy. Today I raised my push mower high in the air to scrape out the deck. In the fall I plan to use it to raise my snowblower to a comfortable height in order to service it before install ( no since working on the ground).
mickeyd
Mar 21, 2014
1,192
Guin, AL
I have used my LP QA Pallet Forks for the past 4 years to move more things than I ever thought possible. I even got the 60" extensions to handle even bigger items.
Since my neighbors know that I have the forks, they have requested me to help unload large/heavy items for them.
edritchey
2026 Kubota ZD1211L-3-72, 2025 New Holland CNH WM75, Landmaster L5W UTV
Jul 19, 2014
1,185
961
Wellsville, PA
I use mine for everything from moving my shop 6 yard dumpster around to loading and unloading skids of Enviro bricks. My forks are probably used as much as my bucket. :)
NWAZL3560
L3560, LA805 loader, BH77 backhoe, rock bucket, box blade, pallet forks
Jun 11, 2018
128
58
Mesquite, NV
I sure agree that they're probably the most used tool for me. The previous Owner left tons of stuff on our property that needs moving, and the pallet forks have been great for that. I wish I'd paid more attention when I bought the forks with the tractor and got longer than the 36" forks I have though. Moving old cabinets and wood this past week.
Smokeless
3901/Loader/Rear Blade/Box Blade/LP Mower/Pallet forks IH M,,Cub & sickle mower
Feb 5, 2018
237
9
Southern Illinois
Titan forks here also, but i goofed. Bought 36" and should have purchased 48". I figured fork extensions are an option later. Yes, very valuable attachment with us also.
