FEL Hydraulic Issue
gssixgun
L3600, FEL, SnoBlower, Box Blade, Rear Blade, Forks, Cultivator, Plow
Jan 5, 2013
258
47
Sandpoint ID
www.gemstarcustoms.com
If they made the lines opposite they could get swapped, that's why I was wondering if you had the old lines to compare to.
I could come over and tell right away if they are swapped, as the flow does sound wrong.
I am going to try reversing them tomorrow morning, I swore I had it right but maybe I screwed up at the Loader Block that is at least physically possible
Crossing fingers again for the morning :)
7,331
I did think from the pic you might have PB connected to pump instead of return but hard to tell.
gssixgun
Jan 5, 2013
258
47
Sandpoint ID
I am going to try it since both you guys have suggested it, I have tried everything except new Connectors now
I am not sure if it is even possible but at this point I am trying everything :)
Wooohoooo nothing like fixing stuff in the cold
whitetiger
Nov 20, 2011
3,773
2,180
Kansas City, KS
I am not familiar with that valve but I THINK this hose is the power beyond from the loader valve. Where is the other end going? That would have been my first suspect but you say the 3pt is working OK?
[/QUOTE
]Here is the control valve used on the LA680, and yes, that is the PB port.
From the two pictures, it appears the pressure port has the Power Beyond hose attached to it.
7,331
Thanks but to me "pressure port" is ambiguous. Real simple - does it look backwards to you or not?
The constant barrage of pop up ads on this site make studying embedded images on my phone next to impossible :devilish:
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,954
2,456
WestTn/NoMs
I think gs has the P and PB reversed, looking back at his picture and write-up on post #8. Maybe the hoses were not duplicated correctly?
gssixgun
Jan 5, 2013
258
47
Sandpoint ID
Okay., after talking with Wolfman last night on the phone, I decided to take it all apart and start from step one again..
This time I tracked the color codes as best I could
I cleaned up both connectors made sure they were functioning as best I could
Put it all back together switching the two lines
Everything is working as it did before the blow out
Gotta pull the rubber mat and Rubber pedal cover and take them to the car wash before I slip off a pedel and run into something or slip and bust my nugget
Just goes to show no matter how careful up think you were you can still screw up something "simple"
The oil spraying everywhere crated another minor issue but will start a new thread on that
WAS BANNED FOR NSFW PICS
5,164
Save you a trip to the car wash. Buy a bottle of Simple Green and spray it onto the floor mat and any other surfaces that you have oil on. Spray with a little water, and then brush it around with a scrub brush. Hose it off, and when it dries, it will look like a new floor mat. Cost of a gallon of Simple Green at Walmart is $10 + or -.
gssixgun
Jan 5, 2013
258
47
Sandpoint ID
You are speaking a foreign language, :LOL::ROFLMAO::p what are these strange things you speak of, "Spray with a little water" "Hose it off"
We have had over 2 feet of snow since last Thursday when the hose blew, Tis a Wee bit Chilly to be running a hose :cool:
5,164
OK then, still use the Simple Green when you get to the self-service car wash. Didn't think about looking where you live.
7,331
Super!! I am just outside of balmy Baltimore and its even a wee bit chilly for water hoses here.
Now check to see that the 3pt can be raised to the top without blocking the loader. If not have a look at the feedback linkage adjustment.
