Exhaust Extension Pipe
Old_Paint
Dec 5, 2020
1,962
2,161
AL
I start my 1948 Chrysler and keep it running for about a minute, then open the door and back out.
My L3301 sleeps outside at the present.
All that '49 needs is a turret and a little bit of reactive armor, and it would be a threat to an M1A2.
B737
LX3310
Jun 9, 2019
2,022
2,205
I have needed to run lots of motors in my climate controlled shop with the door shut, cant move a car that's on a lift, and they do need to be run occasionally after swapping motors or transmissions.
I have pipes sized to fit exhaust pipe, run them out through the door. For BX and B, I use 1.5" diameter 25' long galvanized flex pipe. I'm still alive! I wonder how many of those rebuking op have run a propane heater in their garage (I dont but they seem pretty common around here). ;)
like this:
Walker (40002) 1-1/2" Diameter - 25' Long Galvanized Flex Tube
thirdroc17
185
35
I'm thinking, always a dangerous thing for me to do, some kind of setup similar to what's been mentioned. Any kind of fan, inline kitchen exhaust, duct booster, etc. that moves a little more air than your tractor does at idle. A simple calculation of engine displacement times RPM divided by 2 will tell you how much the air the engine is moving.
At idle, the exhaust doesn't get real hot, if you have a 2" exhaust pipe dumping into a 4" dryer vent pipe, it won't be as hot as the coming from a dryer considering you'll be pulling some cold in as well.
Route it through a wall away from the door and any house windows.
3,818
THAT’S GORGEOUS!! I want one!
3,818
Check your Private msgs
Pony Doc
SSV75 Kioti LK3054 Oliver 1250
Dec 15, 2020
35
20
Central Colorado
I have treated over 1000 cases of carbon monoxide poisoning and I only saw the worst. In many cases internal combustion engines were the source. Many of the cases were suicide attempts, car running in the closed garage. Accidental car related poisonings are generally due to a compromised exhaust system or a car left running in the garage. Keyless ignition systems in quiet running cars now account for many accidental poisonings but it's surprising how often survivors told me they forgot the car was running in the garage! Relatively low levels of inhaled CO, even 30 ppm, quickly interfere with cognition making it easier to "forget" to switch the vehicle off. Sadly there have been many cases recently in Texas and Oklahoma.
Older vehicles and small 4 cycle engines generate more CO than current vehicles and can lead to severe poisoning very quickly. If you have a digital CO detector having it in the garage may produce some chilling/interesting numbers.
There are such great people on this site, so stay safe everyone
3,818
CO-poisoning is easier than you might think. You can be OUTDOORS and kill yourself with carbon-monoxide because once it enters the bloodstream it subtly continues to take-hostage your hemoglobin. Plenty of deaths occur while BOATING outside on a lake with an idling engine while fishing, swimming, skiing, etc. etc.
