Error Code P3001
NYDiesel9540
LX3310
Sep 18, 2022
NY
Hey folks! I've got an LX3310 and its showing code P3001. Not finding a whole lot of info and the dealer is closed today. Any help would be greatly appreciated. Thanks in advance.
jkrubi12
B2601/LA435/QA54"/BH70/B8160box/BB1254/PFL1242/SGC0554/BX2812APlow/WC-68 Chipper
Sep 24, 2012
403
302
right coast
Mass air flow sensor; you could start by cleaning the air filter. I would remove the air filter & start the engine and see if that has any effect on the code presence.
Apparently bad fuel may also set this code; I also found this:
'To reset these you must start with the key off, press and hold 2 amber buttons on left, turn on key, an A appears in display. Press amber button once and a B will appear in the display, press and hold 2 amber buttons till display changes, then press button once so display says off, press button again and display goes blank. turn key off for a minute then code will be gone.'
Good luck! CODES SUK(n)
Fordtech86
L3200
Aug 7, 2018
4,966
5,919
Pineville,LA
Kubota DTCs do not directly correlate to standard automotive obd codes….
I wouldn’t remove the air filter and try running it…being a relatively new model and likely under warranty, I would let the dealer take care of it…
