engine dies when PTO is engaged
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Ok so I see you have a pto clutch for sale in the classified section on here.... so what was the problem??
matrix$
Kubota ZG127e
May 21, 2022
MD
Very old thread, but my Kubota ZG127e is having the same issue. Engine runs fine when PTO is not engaged, as soon as I pull it to engage it tries to start spinning but the engine just dies. Pulley at the clutch turns freely by hand when not engaged and all deck pulleys spin fine with tension removed. Any thoughts, questions, or answers very much appreciated.
whitetiger
Nov 20, 2011
3,341
1,762
Kansas City, KS
Remove the deck belt from the PTO clutch, start the mower and engage the PTO. Does it stay running?
If it does, shut the engine off and raise the seat. On the top of the gas tank, you will see a fuel shut-off valve with a hose on it. Remove the hose and pull the shut-off assembly out of the tank. A pair of needle-nose pliers on top of the rubber bushing works well.
With the shut-off out, try to blow through the hose barb fitting. If the standpipe at the bottom of the valve does not have a screen, the shut-off is probably plugged with debris.
If it still dies you have an electrical problem, most likely the PTO switch itself.
Post back your results for the next guy.
matrix$
Kubota ZG127e
May 21, 2022
MD
I will go do that right now and post a reply. Thanks for the quick response!
matrix$
Kubota ZG127e
May 21, 2022
MD
So I removed the belt from the PTO clutch and started up. Let it run for a few minutes and then pulled up the PTO switch to engage the clutch- engine dies. Should I still check the fuel valve or is definitely electrical? I'm starting to think so at this point. I should add I just replaced the PTO switch a few days ago. Any thoughts welcomed.
matrix$
Kubota ZG127e
May 21, 2022
MD
Also, just removed the fuel shut off valve. I was able to blow through and feel air come out of the end. The screen at the end of the standoff pipe is also still there.
Anything else you all can think of. I will have to take a look at she schematic and see what circuits are part of the PTO switch and see if it's electrical, but if you think of anything please post. I cant be the only one affected by this same thing. Thanks
whitetiger
Nov 20, 2011
3,341
1,762
Kansas City, KS
You have an electrical problem.
