engine dies when PTO is engaged
freewheel3
MX5000DT LA852, BX1800D, B6000DT, B6200HSTD, B7100HSTD, L185, T1700HX, ZD1211
Mar 9, 2013
333
34
Alberta
deck is turning free, all pulleys are fine, engine is not reving up when PTO is engaged
We're going around in a circle here and its back to sounding like a fuel delivery problem. Since you had to "clean the fuel system" twice, maybe its clogged up again. I'd check that.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
If the engine is running fine all day every day then dies when the pto is turn on, its not a fuel delivery issue. Its either the electric pto or the switch is gone bad. Same exact thing happened to my Toro Proline walkbehind. The switch went out, it didn't supply enough current to engage the pto and could kill the engine because it struggled to spin the pto.
freewheel3
Mar 9, 2013
333
34
Alberta
Huh? How does a pto not engaging cause an engine to power out and die? Im lost here.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
The engine has to be able to power the load, if the electric pto is going bad or if the switch is faulty and not engaging like it should then the engine is trying to work harder to power everything and dies. The deck drive belt wraps around the pto, the engine transfers power from a shaft to the pto clutch then out do the belt then the blades.
Basically the engine is stalling out because it can not turn the electric pto. The pto itself or the switch to engage it is going bad.
cyclehd
tg1860g
May 3, 2013
21
edwardsville il.
I didn't have to clean it I was thinking it was a fuel delivery problem, but I never found anything it was spotless. Even cleaned the gas tank. No dirt. Clean. What about the govener not spooling the engine up when I engage the pto?
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
The governor just put a limit to how fast the engine will go. It as no affect what so ever on spooling the engine. It just allows the rpms to reach a set rpm and wont go past it.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
77
Rocky Face, Georgia
I can engage the pto on mom's JD at low idle and it doesn't kill the engine. In fact from what I have found if you want the eletric pto clutch to last it needs to be engaged at low idle to help keep from burning the clutch out. The engine shouldn't need to be running wide open just to power the deck.
freewheel3
Mar 9, 2013
333
34
Alberta
Post a video. Maybe it'll give us all a clearer understanding of what's going on here.
4,368
Ok so if I have this right,,,, with out the mower deck the tractor runs fine,, now engaging the PTO with out the mower is not a problem am I right so far? Now engaging the mower deck the motor stalls,, right?
I think that maybe I would look at the mower deck gearbox,, just MHO
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Give the right size engine and deck combination your right. I have a 14hp Kohler motor on a 44 inch deck on my Toro Proline and I have to have the engine throttled up before I can turn on the pto otherwise it'll just stall out.
Even your method can be a tricky situation, if you start the mower up in thin grass or on a hard surface it works.
Bulldog
Mar 30, 2010
5,434
77
Rocky Face, Georgia
Good point, didn't think about sitting in tall grass.
If it keeps raining here I'm going to be mowing the yard with the batwing again.
Bulldog
Mar 30, 2010
5,434
77
Rocky Face, Georgia
That's what I thought to but early on in the post he said the deck turns freely. Don't know about y'all but this one has me stumped.
Bulldog
Mar 30, 2010
5,434
77
Rocky Face, Georgia
Your mower sounds bad. My first impression is that the deck is binding up but I know you said it turns freely. I guess the next step is the pto clutch itself. I still don't understand how the clutch slipping can kill the engine but I'm not a mechanic either. Good luck and keep us posted.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
An electric clutch can be a funny tricky thing. Sometimes they don't out right die and stop working. They linger for a while and work half assed. I've replaced many of them through out the years. Its a simple replacement.
uglyboy
TG1860G
Mar 8, 2013
87
St. George, Ontario
cyclehd... you've asked a couple times about how does the governor spool up the engine when the PTO is engaged... are you saying the throttle does not get the engine running fast ?
while the throttle (left side of steering wheel) controls the engine speed... when additional load, like engaging the PTO, is applied, the governor essentially opens the throttle plate in the carb a bit more to try to maintain engine speed under the increased load. If you've had the carb and or throttle linkage plate beside the carb off, maybe the linkage was put back together wrong.
another way to apply a sudden load is to open the throttle to get the engine running at a medium to high speed, then mash the HST pedal... if the engine does not try to maintain rpms, then you may have a governor problem.
Pete
4,368
This may not be a part of the problem, but I stopped to see an old hotrod buddy yesterday, he has a new butoa in the garage and was not real happy with it, its a gas mower and was doing the same thing stalling when the mower was started. Now his wife works at the local butoa dealer so of course they came right down,, to make a long story short the dealer replaced the fuel delivery system with an older type of I think he said from an 05. The dealer told him that the mower pulls so much off the motor on start up the fuel delivery system cannot keep up and so it stalls. He says it works really good now but is one thirsty SOB.
