aquaforce
L245DT FEL, JD450 Track loader, 5' scrape blade&mower, 5x10 trailer, Dump truck
Ok, need info.
I need to get the liners out of my engine. These are dry liners in this Z750 two cyl. I started out burning four weld lines down the length of the liner trying to shrink it and then just bump it out no luck.
Now I'm affraid that I might have burned through one of the liners in one spot not good.
What advice does anyone have for this task?
Machine shop is out of the question. He says that cutting them out is the way he would go at over $120 per hole I can do that my self for free.
How would you install the new ones? Is there a sealant or something that goes between the block and liner. My shop manual has no info on this
