DPF Decal is confusing
whatsupdoc
L3302
Jul 9, 2024
163
189
So the other day I had the regen light start blinking on the tractor and and I ended up doing a parked regen. All three lights were on, one I believe was blinking and there was no beeping.
So as its doing its thing I looked at the DPF decal and realized that in column 1 under where it
says "Do this" "Push button(light off)" they are using it as a noun a thing not a verb like to push a button.
whitetiger
Nov 20, 2011
3,549
1,978
Kansas City, KS
If one reads the decal from top to bottom, it makes perfect sense.
The second line says, "If tractor is being used indoors, or in a combustible area, push the INHIBIT button (will light up)."
If you have pressed the inhibit switch, you need to press it again to shut off the light. If the light is not on in the inhibit switch, there is no need to press the button. You just rev up the engine until the increase RPMs light extinguishes and continue to run.
5,211
One more reason to keep the gobermint out of everyday life
