Don't buy a bigger tractor than you need.
10,028
Im surprised there’s not information as the drawbars holes can’t be for weight reduction and even if they did make a longer drawbar, these engineers could calculate the reduction for the spec sheet.
Am I missing the purpose of 3 holes in the drawbar ?
This might help. The piece bolted to the drawbar is called a hammer strap. The two smaller holes are for the bolts that secure it to the drawbar. When towing off the drawbar, Kubota recommends using the hole nearest to the end of the bar (shown on the left).
I started a thread last year that got me going down a rabbit hole.
Wooddog63
In the plan- MX 6000
Mar 31, 2025
21
21
NJ - NY adirondacks
Nothing wrong with going down a few rabbit holes- great posts McMXi
Going back and rereading your thread above on the loading got me thinking. Your so over the target with the math looking like it works but can those 3 point loads handle the stresses is the elephant on the tractor.
So taking your points ,I’m going to look at bolting 2 16” long matching piece flat stock with that stock 26” draw bar sandwich in between and extend it the 6-8” creating a U shape throat that could be filled solid with stock and welded, plated the end and bolt your Pintle idea onto it. Now the Berkleman connects with its swivel and all the tractors center pull energy would be equal. Now the tractors pivot with trailer is a few degrees over the 90 degrees point. Thanks again for the trouble shoot- Won’t be the first time I put warranty on the line and I can tell you’ve done the same😎
You should post the info on a new thread as your knowledge can articulate more confident -it would be interesting to see responses
Mundra
Kubota b2601
Apr 8, 2025
Gods Country
i am jumping in here to say I’ve looked at the bx and even kioti and came to realize a bigger tractor for us on 2 acres+ we should go with a B2601 with loader and belly mower. I read go one size bigger and after research I think the jump is worth it. As others stated sticker shock going bigger but hopefully the saying buy once cry once will stay my motto!
Wooddog63
Mar 31, 2025
21
21
NJ - NY adirondacks
I can’t see how this modification could not be a safe application to extend that drawbar
10,028
When you refer to T&T, are you talking about top 'n tilt which is Kubota's term for an hydraulic top link and hydraulic lift arm or do you mean a QuickHitch such as a QH10 or QH16? It seems to me that you're talking about a QuickHitch and that's what you show in your drawing above.
Personally, if I were buying the trailer you selected, I would leave the QH off, support the top link with the factory hook, and raise the lower links up as high as necessary to clear the tongue, and tow the trailer with the drawbar.
Speed25
L2501(sold) - BX25D
Apr 23, 2024
278
425
NC
The beauty of our orange tractors is that the resale is so strong! I opted for a larger tractor to start with to get some bigger work done that would mainly be a one-time thing. A few years later with the big work done, I sold the tractor for what I bought it for new. Then I went to the right-size tractor for me. I could've just bought the BX to start with, but it was really the wrong tool for the job and would've taken much longer. A few hours of my time to sell and buy, but well worth it.
Wooddog63
Mar 31, 2025
21
21
NJ - NY adirondacks
Sorry new on the Tractor terms and did not clarify- I’ve got some physical issues and my impression was with the Top and Tilt I could attach the quick hitch to make rear implements easier and control a rear grader pitch with out physically getting off tractor and manually making the adjustments. Not looking for speed as much as ease. That caused the drawbar issue with out having to remove that quick hitch but circle back to your numbers I would not want to pull that BW trailer loaded off the 3 point hitch connected to the QH with a trailer ball assembly . With no data you shook me to reality on that one. But , I feel you sandwich plate the top and bottom of that draw bar so there’s an extension, I’d be a little hard pressed to think that would cause any additional stress on the connection from draw bar to tractor or the transmission by the equal extensions of the drawbar . But that’s why I’m here is to learn by people with a lot more experience than I have.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
68
58
Lakes Region, NH
Lengthening the drawbar does increase the bending moment in the draw bar back at the attachment to the tractor due to the tongue weight. Whether or not this would be high enough to bend the draw bar or cause any damage to the attachment at the tractor might be something to consider. Depending on the terrain driven over, the tongue weight can bounce up and down quite a bit.
Wooddog63
Mar 31, 2025
21
21
NJ - NY adirondacks
Thank you for the response - your right with
10,028
You're correct that T&T allows you to make quick and easy adjustments to the orientation of an implement, and in combination with a QH it makes connecting to implements about as easy as can be.
I'm not liking the idea of lengthening the drawbar. As @bobnic said, it increases the length of the lever which has two possible downsides. The load from the trailer will impart more force on the tractor where the drawbar is connected to the tractor, and also it'll put more of a bending moment on the drawbar itself.
Wooddog63
Mar 31, 2025
21
21
NJ - NY adirondacks
I found these interesting -The first photo shows tractors drawbar chained link behind to the 3point tow bar. Problem is what are they towing weight wise
Blue2Orange
BX2380 with LA344S & QH05. SB1051. SG0554. BB1248. RB0560, Vassar dirt bucket
Apr 3, 2025
278
171
Bayview Township
Relatively HOT topic. Just back from the dealer to drop off the check. And... I shouldn't have taken a peak at the used implements. Bigger check. Waiting for the skid plates. The exposure of the BX2380 hydro cooling fan has me concerned.
Own a 40. Based on the chart I have been using an undersized NH. Now couple sizes smaller Kubota is coming. 99% of the 40 is covered in a mix of hardwood and some conifer. Realistically I have a ~1200 foot gravel driveway to maintain and less than 2 miles of ~ 10ft wide trail. Never had an issue with the NH being undersized. At least I can now trailer it if needed to on my 1ton capacity trailer. Time will tell.
NH has a drawbar with a 2" ball to pull a trailer and move a small sailboat in and out of storage. Noticed the BX2380 only has a plate with a hole to attach a ball. Couple issues. Too low a position. Wonder if enough lateral clearance when turning a tight corner. I guess I should have bought a larger Kubota:).
Thinking might need a 3 Pt receiver unit. The bugger might be finding one where I can use the rear QH. If not just the "slow hitch" attachment. Will eventually need to replace those turnbuckle stabilizer arms. Not a good design concept.
bobnic
Mar 7, 2025
68
58
Lakes Region, NH
To protect the hydro cooling fan in my BX2370 when I take it into the woods, I have an Under Armor Skid Plate from Bxpanded.com. You definitely do not want to have a stick get up into that fan as that is a major pita to replace.
10,028
I think I might know the answer to one of those photos since it's my tractor in the first photo. 😂
Speed25
L2501(sold) - BX25D
Apr 23, 2024
278
425
NC
I opted for the Ai2 rear hitch receiver and a 6" rise hitch. Trailer is nice and level when towing, and it spaces the ball far enough away from the back tires that I'm less likely to hit the trailer with the back tires in really tight turns. To be fair though, I don't use a 3-pt on the rear for anything.
Blue2Orange
Apr 3, 2025
278
171
Bayview Township
Thanks for a good solution. Just ordered a Heavy Hitch version for a net $125.01. Hopefully from the Rochester, MN manufacturing facility and not a Made in... with kubota orange powder coating and HH name plate.
Ignorant is my middle name. Have a spare 6" drop 2" hitch. Can I just flip it upside down for a 6" rise? Made in USA Curt heavy duty hitch.
Wooddog63
Mar 31, 2025
21
21
NJ - NY adirondacks
That’s nice as it’s bolted to the chassis- the problem with the MX and concerns McMxi brought up is that 3 point hitch engineered to pull 9800 lbs off a QH
