I read in the forum that Kubota tractors have a built in over run clutch. Is that true? I have a L3710 GST.
Bob
Bob
As a side topic Wolfman, have you ever seen a GST L-series optioned with an independent PTO? I must have looked at dozens of them in the past and never came across one. It led me to the impression that the independent PTO was only an option for a gear drive L-series.Your L3710GST can be equipped one of two ways Independent PTO or Non Independent PTO.
If it has Independent PTO it has a hydraulic clutch that does not require an overrunning clutch.
If it has Non Independent PTO is has a overrunning clutch build into it.
I can't say I have, you could be right it might have only been available on the DT's.As a side topic Wolfman, have you ever seen a GST L-series optioned with an independent PTO? I must have looked at dozens of them in the past and never came across one. It led me to the impression that the independent PTO was only an option for a gear drive L-series.
