Do I need more horse power?
DueEast
L2501 HST 4WD
Mar 9, 2021
40
31
Washington
Are your rear tires loaded? If yes then they may be adding too much weight.
Have you tried with the FEL off? Do that first just to see how much better it is.
How about when you try and mow downhill? Is that better? Can you do it at PTO rpm? If yes then that tells you the hills are just too much.
If you arent willing to take the FEL off when you mow anyway then the answer is you need more HP. With the hills, added rotary cutter weight, and the PTO HP needed to run the cutter your machine just cant handle it. I recommend you go with L3901 or better the L4701 or MXseries.
The L2501 is super popular, but once you put all of that weight on it and mow uphill it just cant handle it.
Yup, rear tires are loaded. Sometimes I drop the bucket before I mow but I’ve never removed the loader. I should give that a try, it might be enough to help me out.
DDCD
1964 MF135, L2501
May 8, 2021
160
179
Oklahoma
I wouldn't plan on a 6' with a 3901. I mow with a 5' heavy bush hog brand on my 45/38hp pto tractor and it slows itself down in 6' grass uphill sometimes. Also the big heavy 6' mowers are very long and heavy.
Also are you dragging your mower on the front skids? I do that sometimes to get a really nice cut but it really puts a big load on the tractor.
Rdrcr
Vendor Member
May 7, 2021
740
894
WA
Sounds like you could use more power or another option for your mowing duties.
I see three options; Replace your tractor with another tractor with more power, modify your L2501 (most members here don’t agree), or buy a ZTR for your mowing duties.
However, it’s difficult to recommend anything without knowing how much you value your time or your potential budget.
If you decided to go with a new tractor, I wouldn’t suggest trading your tractor for an L3901. It’s not worth it.
I’d recommend going to either the Grand L or Mx series tractor.
If you decide on going with a ZTR and your property has steep hills and hillsides like mine, I’d recommend something like the Cub Cadet Pro Z 560S like I have. The Pro Z does an amazing job, it’s fast, super safe and built like a tank.
Mike
Rdrcr
Vendor Member
May 7, 2021
740
894
WA
Try that first…before doing anything else.
Mike
DueEast
L2501 HST 4WD
Mar 9, 2021
40
31
Washington
Mike
That’s a sweet mower! If I could justify something like that it would be great, but I would tear up anything but a rotory cutter or flail mower on my property.
UpNorthMI
May 12, 2020
849
566
Up North, MI
Moving from an L2501 to a L3901 will give you another 50% power over what you currently have. I would not worry about the DPF. The extra power is significant and you will definitely notice the difference in hill travel and cutting speed. I would comment that you should stay with a 60” rotary cutter. If you want to run a 72” cutter with decent performance I would suggest a further increase in HP and size, L4701, MX or grand L.
I own both a L3901 and a MX, with the right size rotary cutters you will not be disappointed with performance.
SDT
multiple and various
Apr 15, 2018
3,312
1,102
SE, IN
You will certainly notice the difference in both performance and maneuverability.
SDT
SDT
Apr 15, 2018
3,312
1,102
SE, IN
Bingo.
A 6' mower with a 3901 is pushing things, both HP and weight unless conditions are ideal and cover is light.
SDT
Freeheeler
b2650 tlb
Aug 16, 2018
706
525
Knoxville, TN
To get up those hills you need either more HP or less weight. The old B2650 or the new LX version has about the same hp and lifting capabilities as your L, but weighs a lot less. Mine goes up hills easily with the BH on, loaded rear tires, and a full bucket of gravel. I agree with the folks suggesting you lighten up by removing what you can for mowing. Personally, I would use the tractor to clean and smooth the area that needs mowing once, to make it feasible to then use a ZTR to mow it.
nota4re
Case 580M Turbo; Kioti DK4210SE-CH; Kubota L2501 (Traded-in)
Aug 16, 2019
129
46
Newhall, CA
When the tractor struggles mowing up grade you should be backing off the pedal not putting it to the floor.
If you're new to HST, this could also be a big part of the problem. It's kind of counter-intuitive. I recently did some work which required me to go up and down a steep concrete driveway. In the first attempt, I was in Mid-range and gave it the beans until it almost died about 1/3 of the way up. At this point I stopped, went to Low range and went the rest of the way. The second time I did it, I just kept it in Mid-range and BACKED-OFF the throttle as I hit the steep part.... no problem at all. With an HST, sometimes less is more.
Rdrcr
Vendor Member
May 7, 2021
740
894
WA
Thanks!
My property is pretty rough too. I have to replace blades every year as I move further and further into undeveloped forest with a combination of clearing and ZTR maintenance.
Mike
bucktail
Jun 13, 2016
1,275
197
MN
By rotary mower I assume your using a brush mower. As long as you're just cutting grass and weeds, the extra rpms shouldn't hurt anything. If you're mowing saplings towards the upper end of the rated capacity, hitting rocks or stumps, etc. then you shouldn't as those things put your mower out of balance temporarily. As stated previously, the tractor should be fine running wide open.
5,778
sigh, I'm impressed anyone has the patience to mow 4.5 ACRES of grass, probably every 7-10 days in the summer !I couldn't sit for the 4-5 HOURS doing that, again, and again and again and .....
If you 'landscaped' with a dozer, got the ground reasonably flat, a high priced zeroturn coulddo it in less than an hour. Neighbour does his 2 acres in 23 minutes.
DueEast
L2501 HST 4WD
Mar 9, 2021
40
31
Washington
I do it about every 2-3 weeks in the summer sometimes let it go if it’s really hot. I could let it grow up a ways but I have some noxious weeds that need to stay cut to keep under control. Next year I plan on buying a 3pt sprayer and spraying to kill off most of that and hopefully establish some more grass. If it was just grass I probably would only need to mow every month or so. We don’t get a lot of rain in the summer.
Rdrcr
Vendor Member
May 7, 2021
740
894
WA
I went from 3 hours mowing with my tractor to an 1 1/2 with my ZTR.
The ZTR was definitely worth the investment!
Mike
thirdroc17
185
35
I've run tractors from 8 to 95 horsepower, and at one time or other, they've all needed more horsepower. LOL
DueEast
L2501 HST 4WD
Mar 9, 2021
40
31
Washington
To follow up on this old thread, I’ve been dropping the loader before I mow and it’s a totally different machine. I can climb my hills in M gear. Cuts my mow time in half so I can easily get the whole field done in one shot. Also saves a little fuel, which this year is a big deal.
5,778
Nice to hear you found a GREAT solution !
When I bought my BX23S, 1st thing dealer said...'do you want the MMM' ? I laughed and said NO, it's a TLB and for the price of the MMM option, I can buy THREE 'riders' to CUT GRASS.
I use it to dig and move stuff NOT 'lawn care operations'.
