Damper on hydrostat pedal
mcox8051
BX23S
Sep 20, 2024
19
New here. I've been tinkering on a BX23s. The hydro pedal does not go back home like a previous tractor I had, in other words, it kind sticks, especially in reverse. Looking at diagrams I do not see any springs on the pedal system. I do see a damper. Is this what makes the pedal go back to home or neutral position? Part number K2651-42150. It only has 79 hours but the damper on the tractor does have a broken dust cover.....digging further, I found there is a "neutral spring" on the transmission. I haven't checked yet but I'm guessing the spring is either missing, disconnected, or broke. Is this hard to get to? Any help appreciated.
Dustball
2016 B2650HSDC
Sep 15, 2023
519
383
Hudson, WI
The damper isn't a spring, it only resists quick motion in both directions. It's there so that if your foot slips off the pedal, the pedal slowly returns to neutral instead of slamming you to a stop.
10,866
The Dampener does not do that.
There is a procedure in the WSM to adjust the pedal Neutral hold position.
Old Machinist
Kubota LX3310 cab, JD4410, JD F725, Swisher 60", etc.
May 27, 2024
678
796
NE FL
If your tractor is less than 5 years old have the dealer check to see if there is a TSB on the problem. They will need your serial number.
mcox8051
BX23S
Sep 20, 2024
19
Thanks everybody! Checking for spring and ordered a service manual.
