D1105 failure to start - need ideas
Kubota_Mac
ZD28 l2015
Feb 19, 2023
25
Here is link to a video of a start attempt. This is after warming the engine up toasty with a propane heater, and it is up to almost 60F here today anyway. Also gave it plenty of glow plug time.... no joy.
11,139
The video sound / looks like lack of fuel and glow more than lack of compression???
It's not cranking very fast though?
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,208
1,823
Pittsburgh
Ah! That is Q'doba's trippple vortex system. The EDBD engines get those.
sitric
L2850DT Ferguson TO35
Jan 13, 2023
82
62
I didn't think it sounded like it was turning over very fast either. Also there are several blogs out there, about new loaded heads not functioning correctly, even with lapping them yourself. Don't want to disparage any vendor, but KB is especially known for it.
Kubota_Mac
ZD28 l2015
Feb 19, 2023
25
So what do folks have to do in such a case?
Kubota_Mac
ZD28 l2015
Feb 19, 2023
25
was that thing ran hard and got overheated? usually thats what causes cracks.
It was overheated about 10 years ago. A tree branch pulled a water line off and it wasn't noticed in time. Ran fine after that up until last summer.
sitric
Jan 13, 2023
82
62
Kubota_Mac
ZD28 l2015
Feb 19, 2023
25
It is cranking as fast as it ever has. If it had low compression, would it be cranking faster than normal? Does this seem too slow to start? The white vaper is the fuel I believe.
11,139
I really think all signs are pointing to a head issue.
I would pull the head and first do a pre chamber test and go from there.
For giggles i would also use the now used head gasket bolt the old head on it, and WITHOUT filling it with any coolant do a compression test and if those numbers look right that answers that question!
sitric
Jan 13, 2023
82
62
I think NIW is steering you in the right direction. You think buying a loaded new head would work out of box, but nonOE stuff seems to come with its own set of problems
Kubota_Mac
ZD28 l2015
Feb 19, 2023
25
Thanks all for your help. it ended up that I just needed to spin the engine faster to get it started and the fuel lines all clear of air. Put a 200A charger on it in boost mode and got it running tonight. For those in a similar situation, don't go down a rabbit hole thinking 150PSI compression is too low to start on a new ring job. It's running like a top now.
11,139
It does build up higher compression when it spins faster!
Excellent to hear you got it fired up!
3,115
Great that you have it running now.
I know that on my old L185 it would fire off turning slowly when battery was weak. I eventually replaced the battery and the starter and it would spin much faster. The old starter was just so bad that it couldn’t be rebuilt. I think you might be able to get the gear reduction type starter if you want, I didn’t even know to ask about that though so mine is still the old school version.
Does that model tractor have any way to release the compression during cranking which helps mine spin up and then start easily.
What are you going to do to get it spinning faster or do you have any plans other than just happily listening to it running for some time now?
11,139
That's a very new model engine, already has the good starter and no decompression on newer engines.
He should be fine as getting it started and running will seat the rings and raise the compression to a good level so it should start and run easier from here on out.
Vigo
B6100, B8200
Jan 9, 2022
595
342
San Antonio Texas
This is a great thread. People talking to each other at a high technical level, OP answering questions quickly and directly, no nonsense spread around (except as comic relief), and then the tractor runs! Gotta love it.
I think the biggest clue for me came from that video. It was cranking slowly. Not too slowly to start a warm engine that's already in running condition, but dubiously suspiciously slow for an engine missing half its cranking compression!! It should have been going much faster than that with 150psi compression IF there was nothing wrong with the starting circuit.
So im glad it's running but i would still encourage to improve that cranking speed. Could be wiring or could be inside the starter. Voltage drop testing could tell you. Either one could be DIY'ed by anyone who already knows how to rebuild an engine. (y)
