Custom B2650 toolbox
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
After buying a 5/16 grade 43 chain that was 12ft long that I cut in half to have two 6 footers with hooks to add to my collection, there is no where to keep them on my B2650 to lift or rig things when you need to. I decided I needed to fab a heavy duty tool box to mount to the tractor to store them. I decided to fab and mount one to the loader frame where there is 2 existing holes. I got some 1/8" steel plate and cut it to make a 10 1/2" long x 8" high x 4" wide toolbox. This size fit nicely in this spot and not be in the way or be too low to snag on something. I welded on 2 grade 8 3/8" bolts to the back of the box to mount it using a jig I made to make sure the bolts were aligned perfectly. The biggest problem I had was how to mount the lid. I couldnt mount hinges on the inside and open it towards the tractor due to things in the way. I didnt want to bolt or weld hinges on the outside because I wanted a nice clean look. I decided to make the lid pivot in the front and swing open, with a spring mounted there to hold it down in the front and a heavy duty draw hasp in the back to secure it.
billrigsby
Mar 17, 2015
1,004
160
Florissant CO USA 8213'
www.facebook.com
Very nice, excellent work
Bill Rigsby
Florissant CO
1972(?) KUBOTA L-1500-DT
Great Bend M10 48" Front End Loader
Bush Hog 48 (SQ48R-3) "Squealer Mower"
Atlas 48" Landscape Box
48" Harrow Rake
Rhino 60" Rear Blade
4 Seasons haul-all Dump Trailer
Leinbach L7200 Post Hole Auger (9")
Draw Bar with 2" Ball
28" Fork Lift Forks
Sent from my Samsung Galaxy S7 using Tapatalk
Yooper
3901 LA525
May 31, 2015
1,464
433
NE Wisconsin
Excellent spot for a chain box at an excellent height! Good idea for the cover! Enjoy your build!
lescarpentier
B3350
Oct 12, 2016
73
Washington
I admire the creativity of metal workers,spoken by a man who works with wood.
Sure would love to buy one of those.I think the placement and design is genius.
aarolar
38
Augusta GA
That's pretty slick right there. I need some of that chain too my rusty stuff is perfectly camouflaged in the leaves.
Sent from my SM-G900V using Tapatalk
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
Thanks for the comments Yooper. Appreciate them coming from someone that has the talents that you do in fabrication. A friend of mine owns a machine shop and has all the toys, so I have seen some pretty neat projects. His shop enables me to do some dumpster diving and get cut offs for my little projects. I do everything in my shop with my little welding table I made, 4 1/2 grinder for grinding and cutting out the pieces I need, and my Lincoln 140 amp mig welder which I am still learning on. It does help to have time to do things now.
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
Your my kind of guy. Keep it going! BTW, does your welder run on 120v?
Yes. It runs on 120 or 240. I have been using it with the 120.
Spectre381
Kubota B2650, LA534 FEL, SGC0660 Grapple, 42" forks, ballast box, ratchet rake
Aug 18, 2016
47
NC
Now I don't care who you are... that right there is SWEET!!
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
Grouse09 and lescarpenteir thanks for the comments. Appreciate it. I have become real good freinds with the owner of the Kubota dealership where I bought my tractor. When I showed him my toolbox the first thing he said is that he wanted me to make some more for him to sell with a tractor if someone was interested. Might have to think about fabbing up a few more to put out!
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
I found the 5/16" chain at Lowes of all places. It was orange grade 43, 12ft long with grade 70 hooks on it in a package for like $28.00. I wanted 2-6 footers so I bought another set of hooks and cut in half. I was wanting to get that chain but never dreamed you could get it already painted orange! Bonus. They actually had it orange on a roll you could buy by the foot.
aarolar
38
Augusta GA
Is it painted or plastic coated?
