rkidd
After buying a 5/16 grade 43 chain that was 12ft long that I cut in half to have two 6 footers with hooks to add to my collection, there is no where to keep them on my B2650 to lift or rig things when you need to. I decided I needed to fab a heavy duty tool box to mount to the tractor to store them. I decided to fab and mount one to the loader frame where there is 2 existing holes. I got some 1/8" steel plate and cut it to make a 10 1/2" long x 8" high x 4" wide toolbox. This size fit nicely in this spot and not be in the way or be too low to snag on something. I welded on 2 grade 8 3/8" bolts to the back of the box to mount it using a jig I made to make sure the bolts were aligned perfectly. The biggest problem I had was how to mount the lid. I couldnt mount hinges on the inside and open it towards the tractor due to things in the way. I didnt want to bolt or weld hinges on the outside because I wanted a nice clean look. I decided to make the lid pivot in the front and swing open, with a spring mounted there to hold it down in the front and a heavy duty draw hasp in the back to secure it.
