Cold Weather Start Up of L3800
ipz2222
L235, bx2670
May 30, 2009
1,927
chickamauga ga usa
Simple solution, put a push botton start switch on the dash or out of the way place. One side to batt and other wire to starter solenoid. When it doesn't start, make sure all implement switches are off. Key on and press to start. Then you can get it to where you want it to ck out and fix. I'v used mine twice on my bx. Tractor Supply has the switches, it's rubber coated also.
8,695
Check all your battery connections especially the ground, intermittent grounds will do exactly what your talking about.
Pull the cables off at the ends clean both sides of the connections put a little lithium grease on the connection and tighten firmly.
tsafa
Kubota L3800, FEL, F550 Dump, 10K Trailer
Nov 3, 2013
152
Tobyhanna, PA
It's happened to me only one time since. Rocking the peddle and jumping up and down in the seat seems to fix the problem. I look like an idiot jumping up and down in the seat and rocking the peddle like I am trying to kick start the tractor. I spoke to my dealer today and they told me that the next time the tractor comes in for service they will check it out.
8,695
The only way I would be happy to watch a video of you jumping up and down on your tractor would be if your name is Kate Upton or at least your attributes match hers!;)
4,001
Wolfe now I got to clean my puter screen again,, BUT, Im sure there might be some sweet young things that wouldn't mind posting with a sweet orang tractor,,,teheee ok so Im a perv
Fishman1
L3800fel
Jan 21, 2012
15
Maine
I had this happen to mine a few times with under 60 hours. Dealer replace seat switch under warrantee but turned out to be the hst pedal linkage in need of lubrication. Pedal is very sensitive to position. I spray mine with WD40 every once in a while, no issues since. Hope this helps....
PrairieSoul
B2920 BX2755HD LA364FL BH65
Dec 23, 2013
22
Manitoba
I had something similar happen with my B2920 this summer while digging in dusty sandy soil. Eventually found it was a sticking safety switch/rod on the HST.
This video gives a fairly good description of how the switch can stick. I regularly spray the rod with a lubricant now. Something thin so it doesn't bind in winter.
http://www.youtube.com/watch?v=KvxjsaKeXCw
