Cannot remove grease gun from fittings
redfernclan
154
Sweet home, Oregon
Been greasing things with zerts most of my life. Yes, loosening the tip will help, but I don't like that way because it also leaks out and makes a mess. The whole trick is in the nipple. There are three little collars that under pressure, lock onto the zert head. After you grease the pin, shove the nipple onto the zert harder and maybe twist a little. That will releave the pressure and allow the collars to release and you can pull it off. The newer the nipple, the tighter the grip.
3,102
and for the 30 bucks....those three jaws of the lock-n-lube are the shyte!:D:) and no messssssss!:)
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
I greased the haybaler, today, Hesston 5530, only has one fitting that is a little dicey, cause of the added length of the lockNlube tip. Still I love how I can lock it on a fitting, above eye level, and use the hose, to pull myself up on the tire, to get the fittings on the top hinge...:D
3,102
now - i aint tried that .......mmmmm.....one toough tip!:D:)
m32825
L3800HST
Jul 12, 2013
227
44
Central FL
I ordered a Lock and Lube and used it today, works great, thanks guys!
-- Carl
DBCSteve
B2650, FEL, box scraper, Artillian forks & grapple, GR 2120 mower
Jul 23, 2011
37
Snohomish, WA
Ordered my LockNLube through Amazon late afternoon on June 10, delivered June 13. Works perfectly, and comes with extra parts to rebuild head (extra insert and jaws). Just ordered another one for my father-in-law.
3,102
It is well worth the $$$$ - that is for sure - one of those things that if you could try it first and then buy it......it would sell for more money. Well designed and the fact they give you extras from the get go is a nice touch to boot!
Orange Turbo
MX5100, pto13000kw, Loader, Ripper,Plow,Disc,Mower,Forks,3pt spreader,Box Blade.
Feb 2, 2015
175
Mo
After reading this thread my curiosity got the best of me...:rolleyes:
Now I'm 30 bucks poorer, Gotha try one......
Thanks Guy's!
