can enyone identify these strange items???
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
9
Leafy England....
hi all,
I have a question for you all out there, can you identify the items pictured below.
I found them last year in tucked away in the wall cavity in one of our barns that i was restoring.
When i first saw themtucked in the cavity they were very dirty, and i couldnt see the writing on them, i suddenly thought i had found some rare religous artifacts hidden away for hundreds of years:cool:, but no, something not quite so rare by the looks of them.
I think they are early 1900's maybe 1920's , but could be anything.
They have me baffled and most of the locals too, i wondered if they were specific to our location but no one appears to be any the wiser.:confused:
maybe someone here can shed somelight on what they are.
rob
re54drider
L2800, FEL, Bush Hog
May 9, 2011
66
Goldston, nc
Warminster Dewey Museum
WAMDM:D10151
Support
piece of iron inscribed clutch for soft ground, discovered under the pitch at Warminster Cricket Club, Sambourne Road, Warminster, Wiltshire, by Roy Dunstan, 1993
Whatever that means....perhaps some sort of aerator tine?
maj_primate
B6100 HST
Jan 6, 2013
31
Summerfield Florida
Reminds me of a golf tool. When your ball comes down on a soft green and leaves an impression you stick the spiked end under the impression and pry the dent up. Usually you then step on the the area or flatten it with your putter. My guess -- Cricket balls are very hard and the crease where the batter does his work must be very flat do to the fact the ball must strike the ground before it reaches him. An uneven spot or divot would affect the ball and give the bowler (pitcher) an advantage.When a batsman grooms this area it is sometimes refered to as gardening-- and sometimes they do it just to throw off the bowler. This is my understanding anyway. Given that some of these objects were found on a cricket pitch it makes sense that it could be a tool carried by batsmen, like golfers carry a divot tool. Maybe our friends accross the pond will have some input. Tom
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
What are the deminsion and what does the back side look like? Only think that comes to mind for me is some sorta key.
2,808
And what material are they made from?
maj_primate
B6100 HST
Jan 6, 2013
31
Summerfield Florida
Wow Like to know what words Stoned Oli used in his search . He does have strong google fu. Even after getting to the web location he posted it took me awhile to get to the exact text on my own.
Hats off to him. Tom
Then I tried ( iron clutch for soft ground)as the google phrase. Clicked 1st listing, a book. A very small picture of item is visable. Same as OP.
KUBOTA4900
KUBOTA M4900SDC & LA100C LOADER,PALLET FORKS,BRUSH HOG BOX SCRAPER 3PT HITCH
Feb 3, 2013
65
durango colo la plata co
I must agree looks like some kind of water key to open water line or open something hav you tried posting them on u-tube ill bet you get your answer within dayz of posting
i found a old wrench lookin tool didnt know nada about it posted it on u tube and found out it was a old rail road tool used by the track gang ????????
Worth a try
tony
