Thank you!Engine is rated for 3,200rpm.
So anywhere close depending on your unique situation.
3000 to 3200 will be just fine imho
There is (probably) a speed marked on the tachometer for PTO speed if the tachometer is analog type.Can't seem to find a clear answer to this. I have a BX2660 with a 60 inch mid mower, what RPMs should I be running at when I mow?
Thank you Russell, its a digital tach.There is (probably) a speed marked on the tachometer for PTO speed if the tachometer is analog type.
There may be two markings but I would think there is only one marked and it is used for rear and mid PTO since they both can probably be run at the same time. It should be near maximum engine RPM.
I can see myself sitting with two hands on the throttle, trying to hit 3043 exactly then watching it change as soon as I start movingEngine 3043 RPM to be exact:
