BX2660 Mid mower RPM
Anil8tor
BX2660 Loader 60"belly mower
Jul 16, 2026
27
42
Can't seem to find a clear answer to this. I have a BX2660 with a 60 inch mid mower, what RPMs should I be running at when I mow?
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,201
1,193
E.
Engine is rated for 3,200rpm.
So anywhere close depending on your unique situation.
3000 to 3200 will be just fine imho
3,153
There is (probably) a speed marked on the tachometer for PTO speed if the tachometer is analog type.
There may be two markings but I would think there is only one marked and it is used for rear and mid PTO since they both can probably be run at the same time. It should be near maximum engine RPM.
Anil8tor
Jul 16, 2026
27
42
Thank you Russell, its a digital tach.
  • Sad
11,249
Engine 3043 RPM to be exact:
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
479
552
NE Ohio
I run my BX2380 between about 2700 and 3300 RPM for mowing. It works well within that range. The grass doesn't seem to know the difference.
3,781
2,184
My BX2370 has a mechanical stop for PTO speed; pull the throttle lever down until it hits the stop.
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
800
1,492
Somewhere between 3042 and 3044 should be close enough.
I asked almost the same question somewhere on here when we first got our tractor with a mid mount mower a little over a year ago.
