BX25D question…
Mowbizz
Bx25d
Aug 19, 2021
618
357
I know my left front axle leaks so I put some 90weight in last week and all of a sudden a giant puddle formed beneath it…could I have overfilled and the oil expanded and blew out the “vent” wherever that is?
sagor
Jan 9, 2017
309
90
Sudbury, ON, Canada
There is a breather plug on the top of each side, and if not removed during filling, air cannot escape and heat/expansion can cause more oil to drip out via the seals due to pressure buildup.
Mowbizz
Bx25d
Aug 19, 2021
618
357
Oops! Didn’t know the breather plugs had to be removed! I hope that’s all it was!
whitetiger
Nov 20, 2011
3,718
2,140
Kansas City, KS
You could just replace the failed seal and be done with it.
Mowbizz
Bx25d
Aug 19, 2021
618
357
I discovered a “leaky hydraulic hose” that is U-shaped where the metal lines are stuffed between the loader frame. I’ll see if the hose fittings are loose and go from there.
Mowbizz
Bx25d
Aug 19, 2021
618
357
That hose definitely had a “wear-through” spot on it just behind the elbow connector. Removed the hose yesterday and brought it to my local dealer. $55 later I’m back home trying to install the new hose the way the factory had it installed in a contorted, tight U-shape but I couldn’t get it to do that. I re-routed the new hose so it could be connected but it conflicted slightly with the FEL “stand” that you put down for FEL storage…I devised a rubber housing to protect the new hose in its new position…no leaks so far and I’ll be watching that hose for any rubbing from here on.
