BX25D question…
Mowbizz
Bx25d
Aug 19, 2021
616
357
I know my left front axle leaks so I put some 90weight in last week and all of a sudden a giant puddle formed beneath it…could I have overfilled and the oil expanded and blew out the “vent” wherever that is?
sagor
Jan 9, 2017
309
90
Sudbury, ON, Canada
There is a breather plug on the top of each side, and if not removed during filling, air cannot escape and heat/expansion can cause more oil to drip out via the seals due to pressure buildup.
Mowbizz
Bx25d
Aug 19, 2021
616
357
Oops! Didn’t know the breather plugs had to be removed! I hope that’s all it was!
3,703
2,123
You could just replace the failed seal and be done with it.
Mowbizz
Bx25d
Aug 19, 2021
616
357
I discovered a “leaky hydraulic hose” that is U-shaped where the metal lines are stuffed between the loader frame. I’ll see if the hose fittings are loose and go from there.
