BX25 Rear Differential
Krehling
Bx25
May 12, 2017
PA
We have a BX25 with less than 200 hours. The rear differential gear broke from the posi-lock engagement lever. I have an issue with it breaking with such low hours. The dealer said there is no replacement that it must be rebuilt. With the cost being $5100 which includes $3500 in labor. Has anyone encountered this before? Any other options?
2,235
Not being critical here - but was it used correctly? Spinning wheels and engagement would be my first thought of breaking. Should be no way to break the ring gear unless the gear itself was spinning rather quickly.
I have about the same hours on the same machine, I have used the diffy-lock about 10 times, and 99% I was in the mire and muck. Each time I am looking at the wheel spin and then stop to engage the lock, sometimes I had to give it a little movement to have it engage however.
The cost seems high to me too - I would think you could replace the entire rear end for that!:)
rookiefarmer
1972 L260
Nov 1, 2011
82
Colfax, IN
That is definately the weak link in the BX series tractors. I am currently rebuilding a BX2200 and that's what happened to it. Diff lock pin sheared exploding the spider gears and punching a hole in the aluminum case.
I agree that the price is WAY out of line. Try calling around to other dealers
4,890
1,624
Only time I've seen one broken was overloading, or spinning wheel and then it grabs. Break it every time. I wouldn't consider it fragile, but it'll happen with the right conditions.
$3500 labor? My goodness whats his labor rate, $350/hr? That is certainly questionable. I wouldn't figure much more than 12-14 hrs to do a trans overhaul. Once out of the frame it ain't that hard to rebuild one.
SkylineAcres16
Kubota MX5800 HST, International B-275 Diesel
Sep 3, 2016
40
I literally saw one the other day in the shop and they were replacing the transmission. I asked what happened and he said they used the differential lock while wheels spinning. It looked like a very costly repair.
4,171
I have to use my diff lock regularly. Do the same routine as Hokie.
I always viewed it in a similar fashion to getting my Chevy Silverado spinning in 2WD, and engaging the 4WD. I do put it 4WD while driving, but never throw in 4WD while spinning.
It's of no help to the OP and may not be the cause of his break, but maybe others will take note. Engaging the lock on the fly/spinning is known to cause problems.
kuvasz101
BX 1870
Dec 28, 2019
Feeding Hills, Ma US
I notice all the rear differential locks that have sheared off are on the BX25 models. Does the BX18 series have diff lock problems as well or is it just BX25 specific?
Lencho
B7100hst
Jan 21, 2017
410
87
NM
I think it applies to all models not just bx series.
4,171
Absolutely. I wouldn't slam the diffy lock on any tractor while spinning.
Still won't slam my Chevy into 4WD while spinning either.;)
SidecarFlip
Banned
550
Or my Ford or the wife's Suburban or either of my M9's for that matter. Engaging any diff lock on a spinning mass is inviting disaster.
You can grenade anything with the proper abuse.
Labor sounds a bit high but them maybe the dealer really don't want to fiddle with it and shot a high price because...
bet the OP won't pull that shot again.;)
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,130
127
Hardisty, Alberta
Flat rate time from Kubota to replace differential gears is 11 hours. That is what they pay the dealer for warranty repair. You can bet they aren't overpaying!
