BX23S Roof Project
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,186
876
PNW-WA
After a year away on this project, I'm back at it. The frame and uprights are UniStrut, aswell as all the brackets that bolt it together. The front supports will be attached to custom aluminum L-Brackets, using the two existing holes in the floor pan, near the foot pedals. Custom lighting mounts have also been made and ready. The skin for the roof is sheet aluminum. 1000070628.jpg
Trimley
Jul 25, 2023
1,186
876
PNW-WA
Someone is playing with an erector set.
Indeed. I've only got $200 invested in it over a two year span, so I figured I'd give it a try. The assembly is pretty straight forward, the way it's all tied together with the brackets, bolts and nuts, I'm skeptical it will remain tight. All the brackets, bolts and nuts also add a LOT of unnecessary weight. Given that, I may end up taking the frame work off the tractor and weld it all together, which will resolve a LOT.
5,490
Looks good (y) 👏
I would use lots of "blue" locktite (medium strength) on the bolts to help combat the vibration. 🤷‍♂️(y)
