BX2380 PTO disengaged and won’t re-engage
ram4x4
Irwin
Thanks. Yes I’m sure the dealer cost would have been high. It’s nice to be able to work on these machines yourself.
FloridaOrange
BX23S
Apr 28, 2021
31
Unbelievable. I had same problem with my 2019 BX23S. Thank the Lord I was able to find the solution via OTT community. The biggest hassle was notching the frame. Once accomplished, pulling the valve was no trouble. Cleaning the tiny port was a challenge. Silicone packs pretty tight apparently under that kind of pressure. I actually found 2 separate pieces. ( see photo). Hopefully that was all of it. I will reassemble and test it out tonight, but am confident progress has been made.
what a dumb and potentially costly problem to have.
Soopitup
BX23S
Oct 25, 2018
369
164
New England
Well WTF.
This shouldn't be a common problem on these. That's shoddy assembly. Not what I was expecting from Kubota.
ram4x4
Irwin
The pieces I pulled out were very similar to what you show. Try to only reassemble the minimum to test it out as I had more silicone that immediately reclogged the port. Good luck!
turbospeed440
Bx23s
May 11, 2021
Southbury ct
Just an update, I was able to pull the valve without dropping the trans. Sure enough there was a small piece of silicone in the valve. Once removed it worked like it should. As a precaution I dumped all the hydraulic fluid cleaned the screen and new filter. I did remove the 1/4 plug in the valve ,hooked up a hose and started the machine to move some fluid. Sure enough a few more pieces came out.
Hopefully she's good now. I think it was a result of the wood chipper being used all that rattling around caused some small pieces to break
