Just an update, I was able to pull the valve without dropping the trans. Sure enough there was a small piece of silicone in the valve. Once removed it worked like it should. As a precaution I dumped all the hydraulic fluid cleaned the screen and new filter. I did remove the 1/4 plug in the valve ,hooked up a hose and started the machine to move some fluid. Sure enough a few more pieces came out.
Hopefully she's good now. I think it was a result of the wood chipper being used all that rattling around caused some small pieces to break
