BX2370 Snowblower
Puddle
BX2370
Nov 14, 2017
14
Sandpoint
I just bought a BX2370 and am trying to find a front mount snowblower. Is the BX5450 the only option, or will other brands work. I have searched the threads as well as googled, not having much luck, (could be I went to public schools and not too bright)
Grouse Feathers
BX2370, FEL, Snowblower-BX5455, Homebuilt Forks, LP RB1560, LP GS1548
Feb 16, 2015
1,022
10
Lovells, Mi
Most (probably all) front mount snowblowers are brand specific because there is no generic mounting system for the front of the tractor. The 3 point system on the back of the tractor provides a generic mounting system so most rear mount snowblowers will fit on any 3 point mount if sized properly for the tractor.
sagor
Jan 9, 2017
285
58
Sudbury, ON, Canada
If its a standard "quick hitch", the same as a BX25, then you can probably use the BX2750D blower. It comes standard with a manual chute turner, the hydraulic turner is an option...
tcrote5516
BX1860, FEL, 50" Front Blower, Heated Cab, 6' blade, 3pt carry all, 3pt hitch
Sep 2, 2014
482
Southern New Hampshire
I guess the question is what are you looking for the the bx5450 doesn't do/have? You can also mount a bx5455 if your looking for a few more inches but the cost to inches ratio didn't make sense to me.
You can also add electric chute control very easily to either one which drops the total cost from "insane" to just "ridiculous".
I have a few videos of the 5450 on my youtube channel: https://www.youtube.com/user/tcrote5516/videos?disable_polymer=1
Puddle
BX2370
Nov 14, 2017
14
Sandpoint
Thank you all for the replies. I was just trying to find an inexpensive :) alternative to the bx5450 (Ya, I'm new here, now see that isn't going to happen) I think I will have to just get a front blade, I have neck and back problems so I do not think I could run a rear blower.
ORANGE YOU HAPPY
BX23s
Nov 14, 2017
Owen sound,canada
I have a bx2816 snowblower for my Bx23s I think it might work for you . I will check to make sure that's the right number on it .
fatjay
Kubota B8200, B7200, ZD21
Nov 12, 2016
309
141
Eastern PA, USA
I used a blower off a b7200 on a b8200. The models are similar but they're substantially different in size. Still, mounting system lined up, 2 bolts to pivot. I think the biggest hurdle is going to be the mounting of the driveshaft, not mounting the blower. There's about 4' of driveshaft that has to be securely mounted.
